View Poll Results: which differential are you using on your high horsepower turbo car?
Spool
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
14
60.87%
Locker (please post which one)
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
6
26.09%
Welded "Lincoln Locker"
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
3
13.04%
Other
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
0
0%
Voters: 23. You may not vote on this poll
High horsepower turbo differential options and opinions
I have a detroit locker in my 9 inch, my set up is a 6 speed not sure if you are an auto or not but if I had it to do over again I would go spool with out a doubt. The locker is so loud and clunky @ low speeds its almost embarassing.
sarg im at the same point you seem to be
i did a lot of research and talked to quite a few people that all tried to sell me things
took all the advise i got and made my decision
i ended up going with a currie 9in with a true trac and a 3.25 gear
of all the advise i was given that option seemed to come up more then any other
ofcourse mines not a drag setup either but more for road warrior n maybe some auto x
The 9" does seem to come up a lot, but that seems like it is going to be stupid expensive. Currently I can buy for the 8.8:
-Differential $300-$1000
-Axles: $300
-Brakes: $0
-Housing $0
Or 9":
-9" housing with axles set up for a fox $1000
-Carrier and diff $1000
-Brake set up ? maybe another $300-$1000
While I agree that would be the best way to go I just can't justify at this point the massive expense. If it comes down to it I can always get an open diff from a junk yard for the 8.8 with 31 spline axles and do this for $400 and see how it works. At that point I already have my disc brakes and if I hate it I am not out a metric crap ton of money.
-Axles: $300
-Brakes: $0
-Housing $0
Or 9":
im running a detroit locker in my 65 panel with twin turbo lq4 th350 trans,12 bolt gm, 28 inch tall m/t et street. hooks up great and turns nice still with no shuddering, i think ive heard it unlock about 3 times ever, yes its a little loud when it does but the sound doesnt bother me at all.
Do those clutch packs actually hold up, and really grip when you apply power in a right hand turn? With the old school traction lock diffs you might as well have had an open diff when trying to power out of a tight right hand turn unless you added clutches until you preloaded them against the pinion, so I don't think they would be worth a damn for trying to run 9s. These must grip a lot better I guess...
Im going to run a wavtrac in my fox with moser 31 spline axles and c clip eliminators. Just waiting on my tax refund to make the order. The person i talked to about the wavtrac told me to call moser and they would do a better deal for me since im getting everything... And i run street to much to run spool.
Also, my choice was based purely on driveability, not running 9's. I believe the Cobra diff could do it in a light car, but is it optimal? No.
#32
Cool, thanks! I hope to be able to give one a shot in something at some point then!
Are there any options to try to jam a little more spring pressure in there, or not? Seems like I read that there was a stiffer S-spring that people were unable to squeeze into the diff, so that sounded hopeful assuming a person could figure out a way to get it jammed in there...
#34
I don't mean to offend, but I don't really understand the goal of your car, because the drivetrain is kind of drag, the suspension is kind of drag, the brakes are sort of street, and the wheels/tires are sort of road course. I think pretty much any 31 spline (or more) diff/spool will work in your application. Spool will be the cheapest, you can buy one for $150 brand new from Summit.
#35
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I didn't try to modify the Cobra diff at all, I don't ever want another dedicated drag car, 99% street daily driver is fine for me.
#36
If you are worried about a Cobra diff, then automatically rule out any of the inserts which install the OEM diff carriers. My opinion is those products are low budget gimmicks which offer the buyer a sense of security rather than actual security.
#37
A locker will work fine on the street. I've never had one in any of my Mustangs but I have ridden in and driven many Mustangs with lockers. When I say locker, I mean an actual FMS detroit locker type diff, not an insert.
Sometimes, and possibly often, people don't like the "jerk" which occurs in a locker, when the driver punches the gas while going around a turn and the inside tire instantly starts turning the same speed as the outside tire. As long as you expect it to happen, it should not come as a surprise. Some people hate it, some people never notice it at all, it only depends on personality. Honestly, punching it around corners is probably not something you would want to do with a big turbo anyway.
#38
The way a locker works is both beautiful at the strip and tiresome on the street. The locker will unlock the faster moving tire and power the slower moving one always. So in a turn, you step on the gas, ALL the power goes to the inside tire which will make you push through the turn in an ungodly fashion, and/or if traction is lost on that tire you end up with a vicious snap oversteer. If you lift in the same turn, the same inside tire now exerts all the engine braking to the chassis making the car suddenly VERY hungry for the inside of the turn.
Going straight down the highway with traffic, it will randomly lock and unlock whichever goddamn wheel it feels like as you are on and off the throttle staying with traffic, gently tugging the car side to side like you're riding in ruts.
I'm ditching my locker for a Quaife Helical diff and never looking back.
#39
First we had the front end aligned relative to itself, and then we put the car up on blocks so it's weight was supported by the axle and front control arms, IE it was at it's ride height. The we dropped carpentry bob weights from the axle/hub centers to the floor and aligned the rear relative to the front by matching the X dimension measurements from RR/FL and RL/FR.
Basically a combination of a slight front toe out condition and an invisible rear crab walk was sensed by the differential even though we could not see it with our naked eyes. Add that to a huge pneumatic trail on the front tires, and well, it was obvious while driving the car.
After our "fix" it was virtually unnoticeable.
#40
I've seen this before in a Mustang and we minimized it by adjusting the rear control arms to effectively square the axle relative to the front wheels.
Also with a brand new set of tires on the car it was almost perfect in regards to highway driving, but after a few weeks and burnouts, the throttle wander seemed to get worse.
