~Procharger Build Write up~
Old Mar 13, 2013 | 05:21 PM
allout06's Avatar
Originally Posted by flame
The ATI balancer has a key way and requires the use of their pinning kit which inserts the pin 90deg to the crank. You will have to remove the balancer to do that. The pic you have is for pinning a stock balancer. Also no mention of pcv modifications to avoid pressurizing the crankcase. Otherwise good info!
this method sucks. i had mine on for 6 months and the pin was broken, as many others on here were broken. i took my buddies front pinning kit to a machine shop and had them lathe down the jig so itll fit in the ATI damper. worked like a charm.
one thing i noticed it the write up about the wideband. You want it between 0-90*. Condensation can settle in the O2 sensor if its below the the 3 or 9 o'clock positions and damage the sensor. may want to add that.
Also, i never had any heating issues with my single 16" procharger fan.
Old Mar 13, 2013 | 05:30 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Originally Posted by sweet99ss
UPDATE!!! Procharger has updated there front pin kits! Bob told me before mine was shipped out yesterday that he thought they had changed them a bit and he was right! I got my pin kit and the Jig fits right inside of my ATI balancer! So I recommend using the front pin kit for now on!
I'm interested to see this update. I side pinned my crank, and it sheered which then wasted the center hub on my balancer. The hub spun on the crank once the pin broke and it galled up the inside of the hub. On the new build, I had my crank cut to run a keyway and had to buy a new hub. It also screwed up my crank snout. The crank is fine for a now supercharged setup, but wit the extra load on the crank, I didn't want to reuse the crank. I guess I could always have the snout welded and reground.
Just FYI, it's critical to pin the crank in case you ever had any doubt.
sweet99ss's Avatar
I think I said to put it at a slight angle didn't I? I cnt remember and I'm to lazy right now to scroll up because I have a question for you allout! What should the gap be from the crank snout to the inside edge of the balancer? I have a 1/4" gap. Was your gap that big?
Old Mar 13, 2013 | 05:32 PM
sweet99ss's Avatar
Alchemist or Allout do you know how much gap there should be between the crank snout and the inner edge of the ATI balancer? I got 1/4 inch between them
Old Mar 13, 2013 | 05:42 PM
SKULL's Avatar
i might of missed it but what about when you go to a cog setup?
Old Mar 13, 2013 | 05:45 PM
UNDER PRESSURE MOD
What gap are you talking about? I just bottomed mine out and it should line up with both the a/c pullies and the main drive pulleys.
Old Mar 13, 2013 | 05:50 PM
allout06's Avatar
i dont know what gap your talking about either. got a pic?
Old Mar 14, 2013 | 06:38 AM
UNDER PRESSURE MOD
Looking at that picture, I'd say it needs to be flush. Only real way to tell is check pulley alignment. I don't remember off the top of my head what that looked like, and to check it would mean removing the crank bolt, but if I remember, I'll pull it and check.
Old Mar 14, 2013 | 06:45 AM
Fall Line's Avatar
I just did mine and had the same gap (I measured 5/16). I emailed ATI and they said it was right and the pulleys line up.
Old Mar 14, 2013 | 07:25 AM
stealth355tpi's Avatar
I cant remember with mine either but as long as the pulleys line up I would say your good.
Old Mar 14, 2013 | 08:36 AM
conan's Avatar
You want that small gap in between the pulley hub and the crank. This keeps the load of the crank bolt on the hub, pushing it back in to the engine. Just make sure the pulleys line up. I had to shave a little bit off of the back of my ati hub because of my double roller timing chain gear. The hub was bottoming out on the gear and sticking too far out the front of the engine.
Old Mar 14, 2013 | 09:15 AM
  #32
allout06's Avatar
Theres your answer lol.
Old Mar 14, 2013 | 11:38 AM
  #33
flame's Avatar
News to me about the change in pin style. Maybe mines broke and I don't know
Old Mar 14, 2013 | 08:14 PM
  #34
sweet99ss's Avatar
Awesome! Looks like were good to go. This will be good info for people wanting to know in the future. With an ATI balancer for procharger application you should have a 5/16 gap between the face of your crank and the inner face of you ATI balancer..
Old Mar 14, 2013 | 11:16 PM
  #35
js2fst's Avatar
I just had a key way put in my crank
Old Mar 15, 2013 | 09:14 AM
  #36
sweet99ss's Avatar
That's good if you have the motor out or your having an engine built for you, but when your engine is in the car pinning is the way to go..
Old Mar 15, 2013 | 10:08 AM
  #37
js2fst's Avatar
No problems from when it was pinned
Old Mar 15, 2013 | 11:01 AM
  #38
ramairetransam's Avatar
who sells the bolt for doing the ati balancer for 20 bucks , i need to install mine soon?
Old Mar 15, 2013 | 04:48 PM
  #39
sweet99ss's Avatar
https://ls1tech.com/forums/parts-cla...all-tools.html
$20 shipped
Old Mar 16, 2013 | 07:51 PM
  #40
sweet99ss's Avatar
Alright guys my intercooler kit won't come in for awhile and my procharger head unit pulley is on back order. In ideas on what you think I should install next?
