~Procharger Build Write up~
Old Mar 20, 2013 | 05:41 PM
  #61
sweet99ss's Avatar
Welp nobody answer'd so on everything goes lol.....
Old Mar 20, 2013 | 06:49 PM
  #62
The Alchemist's Avatar
UNDER PRESSURE MOD
I guess there's no real harm in it. I wouldn't put on the belt because you run the risk of messing it up if it's not attached and there's no point in spinning the blower if you aren't using it.
Old Mar 21, 2013 | 07:35 AM
  #63
allout06's Avatar
When i did mine. I hooked up everything. Tightened the belt ran the piping. Everything. I left my injectors out and didn't hook up the ic piping to the TB. Ranmy stock air filter and drove it to the tuner. I put my injectors in when i got there and hooked up the ic piping and he tuned it. Pretty simple
Old Mar 21, 2013 | 10:18 AM
  #64
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You can actually hook everything up except for the installation of the larger fuel injectors. You can drive the car across the US this way as long as you stay out of boost. At part throttle the boost is being directed out the bypass valve, not into the engine. Back at the old shop we had many customers bring their vehicles to us this way, many from other states pretty far from us. We would then install the injectors and flash a base tune in to account for the larger injectors, then get the car on the dyno to start the part throttle tuning. Doing it this way breaks in the blower belt, which I always recommend breaking in for an hour, then readjusting belt tension prior to going wide open throttle. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Mar 21, 2013 | 12:07 PM
  #65
allout06's Avatar
I was goin to do that bob, but i know its hooked up so i wouldnt b able to control myself from tryin to go a little faster . lol. So i left it disconnected in case i "forgot" haha
Old Mar 21, 2013 | 03:52 PM
  #66
mjs1012's Avatar
This is an awesome thread. Thanks for taking the time to do all of this!
Random question OP, how do you think your 224r will be with the d1?
Old Mar 21, 2013 | 05:40 PM
  #67
Blackpanther99's Avatar
That cam^ will definately make some boost with his setup.
Old Mar 23, 2013 | 02:36 PM
  #68
sweet99ss's Avatar
That's a good question! I really hope it doesn't bleed off boost! I'm not sure though... it's on a 113lsa so that might help a little bit?
Old Mar 23, 2013 | 08:00 PM
  #69
UNDER PRESSURE MOD
The cam is fine. I'm running a 227/235 on a 113 as well and I build plenty of boost and make plenty of power.
Old Mar 23, 2013 | 08:06 PM
  #70
allout06's Avatar
Hell my torquer v3made good power and its not "boost friendly". It was on a 111LSA..
Old Apr 14, 2013 | 12:55 PM
  #71
sweet99ss's Avatar
Just for an update.. My engine lost Oil pressure so the build is on hold... Got a forged tms motor coming. Getting ready to order a built level 5 rpm transmission. Probably going to run an ls6 cam with Brian Tooley Dual racing springs and up the pulley from the original 5.00 to a 4.50" pulley I have.
Old May 2, 2013 | 10:05 PM
  #72
Johnny_k's Avatar
man u had a nice lil build thread going.
What made ur engine loose oil pressure?
Old May 3, 2013 | 08:20 PM
  #73
sweet99ss's Avatar
No idea. Probably check this weekend. I have the engine out of the car, but havent pulled it apart yet. I have been working 13 hr days in a town 2 hrs from my house for the past month so I can only work on it for a short time on weekends. I'm guessing a spun bearing.
Old May 4, 2013 | 02:26 PM
  #74
stealth355tpi's Avatar
Don't forget about your fuel situation now that your upping the boost.
Old May 5, 2013 | 09:10 AM
  #75
sweet99ss's Avatar
How much power should I make with an ls6 cam, stock 853 heads with dual springs, Lt headers/ory/cutout, ls6 intake and 4.5 pulley on a d1sc?
Old May 5, 2013 | 10:03 AM
  #76
Cam72aro's Avatar
My guess is in the mid 500 range.
Old May 5, 2013 | 12:11 PM
  #77
LS1Tech Sponsor
I'd say around 500 rwhp on a eddy current type dyno with 8 psi. Bob
__________________
Old May 5, 2013 | 05:18 PM
  #78
I'm 8lbs with a 5in pulley, stock long block with bobs blower cam. The 4.25 I tried at first was making 11lbs.
Old May 5, 2013 | 05:21 PM
  #79
LS1Tech Sponsor
Question
What blower do you have? Bob
__________________
Old May 5, 2013 | 05:27 PM
  #80
sweet99ss's Avatar
Bob do you think with the mods and pulley I listed that my fuel pump would keep up? It's a racetronix with hotwire.
