stock 6.0L 8.59@156
#64
Huge Congrats to dudeman!! Dudeman and 6.0mustang are two of the most impressive racers,builders and tuners I have honestly come across in many many many moons of racing...
Both are very moddest so I would like too point out some killer things about these two...... This car and 6.0mustang's car are 100% built by these two in their garages...and when I say 100% I dont mean they bought a turbo kit or a built trans and slapped it in the car... They built their own transmissions,rear ends,assemblied and built motors,turbo kits,wiring,roll cages,mini tubs,setup theier own suspension and ecu tuning.. all done by them.. Thats saying alot in my book!!! They caught alot of stuff along the way and alot of people had no faith in what they were capable of doing.... My hats off too these two!!! CANT WAIT TOO SEE WHAT THEY DO NEXT!!
#65
#66
thanks for the kind words guys.
im taking the car out tonight for some 1/8mile testing. may turn the boost up a couple lbs.
then tomorrow is a little 10.5" tire heads up racing. should be a fun weekend
#67
#68
couple vids from this weekend.
http://www.youtube.com/watch?v=4Hc6q...ature=youtu.be
http://www.youtube.com/watch?v=C5Ycv...ature=youtu.be
#70
i am seriously considering the glide. i have a stock case glide in my garage. i may try to build it to hold the power long enough to see how the car does with it. if it does good i will may try to get a built glide with an aftermarket case.
#73
I just built a stock case glide for my turbo build and my older brother has built some that handle 1,200+HP still going. Although the aftermarket case is better, don't think it's necessary at these power levels.
#79
I'v been enjoying this thread! It gives me hope that my junk might make some power, I currently have close to the same drivetrain, ford 9" with 3.55 gears, powerglide, stock 6.0l with very close to the same cam. I think your on the right track with going power glide, I have over 150 runs on a stock 1.76 gear set in front of my old 496 bbc, many passes were wacking it off the line with a 500 shot of n2o. I bought the tsr powerglide transmission book
http://tsr-racing.com/index.php?rout...product_id=677 it tells you everything you need to know about building a race glide, they are by far the simplest GM transmission.
