Going Procharger, but wich one D1SC or F1A?
I have been reading up on the F1D, it seems to be just between the D1SC and F1A. There is a G8 on here that made 730+rwhp with a F1D at 15lbs of boost, thru a 6L80. I might consider the F1D but I have to do a little more research. I know it is made to make more torque at lower rpms. The price is not the issue, I just dont want any lag or a blower that is so big I only run the biggest pulley sold and never spin it high enough to make it shine.
I have been calling around and the F1D is really looking like a good choice. It can make more power than the D1, and it makes torque quicker. I know it can do 750+ and would run better at low boost because it is suppose too come in quicker. I might consider that, I am not looking to make a 1000rwhp.
I don't want a 8 sec car, I have been reading your thread about being slow, I wouldn't really say 13.01 is running strong, my heads and cam car runs 11.6 on motor, if my car doesn't go mid tens with a procharger, something is really wrong, I am not trying to be a jerk, but I am wanting input from people with experiences with my kind of setup.
if you ever plan on going further...the f1A is prime choice.
My car is already a mid 10sec car, I would like to stay in the tens once I swap from nitrous too a procharger. But I really want is a 9 sec street car with blower and built motor when everthing is done. I will probably just go ahead and step up to the F series. But it won't be a dyno queen, I am more concerned about track times than dyno numbers.
But I am really just waiting on ARP's slow *** to finish my stainless 12pt engine bolt kit. I called today raising hell because its been over a week. they should have had that **** to me by now. holding my build all kinds of up. thanks for asking man. if you wait long enough i will sell the f1-a to you. Its hand polished my man. but itll prob be after holley ls fest this year before I get rid of it.
D1 runing 5.80's 1/8 and 9.20's 1/4 http://www.streetfire.net/video/crossville-dragway-101809-procharged-ls1-firehaw_713971.htm
f1 http://www.streetfire.net/video/8-second-ls1-procharger-11102007_710762.htm
Oh ok I will be awaiting to see what you have going on, with the F1A aren't you are shooting for 900+. I am just looking for a really fun street car that can go to the track and bust a high 9 sec pass. I know a F1A can do that easy but I am interested in the F1D because they say it builds boost faster.
#32
#33
LS1Tech Sponsor
Take a look at the above dyno graph. This was with an F-1A at only 12.4 psi of boost. It is making torque down low, about 400 ft lbs at 2000 rpm! Up top it is making 864 rwhp at only 12.4 psi! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
#34
Bob, what kind of motor in the CTS-V you posted? Im having the same problem deciding on a blower as well. Ive bought all my turbo stuff and decided not to do it, now im debating on what blower for a 382 cube LS3. I had settled on the D1 and now im having second thoughts... again.
EDIT: DUH! nevermind, I see it now....
#35
LS1Tech Sponsor
__________________
#38
LS1Tech Sponsor
Thanks, I appreciate it! Bob
__________________
#39
LS1Tech Sponsor
ProCharger F-1D
Base HP Range of NA Engine: 300-500 HP
Maximum Supercharged HP Rating: 1,000 HP
Maximum Airflow: 1,500 cfm
Maximum Boost: 34 psi
Inlet Diameter: 3.75 inches
Outlet Diameter: 3 inches
Maximum Impeller RPM: 65,000
Internal Step-up Ratio: 5.40:1
Self-Contained Oiling: Yes
Reverse Rotation Available: Yes
ProCharger F-1A
Maximum Supercharged HP Rating: 1,100 HP
Maximum Airflow: 1,575 cfm
Maximum Boost: 38 psi
Maximum Impeller RPM: 74,000
__________________
