holley 12-1800 fuel pumps for FI
#61
For the record, I have 20k miles, countless hours in traffic, probably 150 9 second passes and 6 or so 8 second passes on my Holley 12-1800. Its about 3 years old now, and still totally silent as well as working perfectly. I will be using Holley pumps for every build I have that doesn't need a cable driven setup...
#64
So far my 1400 is OK, I have the sec. pump set for 5 or 6 lbs boost-I can also turn it on man. if I want, kind of a backup if driving and a pri pump failure
The only thing I remember in the instrus. was to point it front to back, but mine is left to right, with one pump on top of the other-I do have it low enough so it gravity feeds from the sump
I have room to mount it flat and keep the lines the same, maybe one day, lol
I think I will mount a light on the dash from the sec pump wiring to let me know when it has power
#65
Quote from the Holley Website on the 12-1800 pumps.
"This pump is compatible with pump gas, but is not recommended for street driven vehicles where the ambient temperature is regularly above 90 degrees"
It's above 90* most of the year in Arizona... Just sayin'.![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
I've already had once side of my pump die within minutes of run time. It was a secondary pump that only came on under boost at the track... Race gas too, no pump gas ever went through it. I have two of these pumps on different cars and both are coming off... Aeromotive 1000 with replace both... Drag Week tested.
#66
I can't count the number of A1000 failures I've seen personally, the number is way to high. But to each his own. I'm pretty sure all of these pumps have made it through drag week anyways. I really doubt the a1000 is the only one.
You want to make real power and not worry about a pump failure with long driving trips? Go mechanical. For anything over 1k rwhp its probably the best way to go, just expensive initially.
#67
I have run them in 100 degree heat for extended periods without issues. Made it from Reno to San Francisco in the middle of august with 105 outside temps for most of the drive. No issues at all.
Love my 12-1400 and it supported my 521 BBF on one pump. Hope it will be able to support my centrifugal supercharged 5.3 truck motor without issue as well.
#68
I can confirm This pump is compatible with pump gas, but is not recommended for street driven vehicles where the ambient temperature is regularly above 90 degrees".
I drove my truck on the Power Tour last year, and on the day-long drive from Birmingham to Ohio it shut down on me while traveling I-75N. I switched the wires, limped to the next exit on the "other" pump in the 12-1800, and let it cool off. On E85 I've yet to have a single issue. Which is fine, as that's pretty much all I run through it anyway. If I were to do it over, I'd just use something like a 255 for normal driving then have the Holley EFI kick on a big 4303 or something under load.
#69
I had to pull my tank so I could replace the trunk pan (rust) so the pump was dry for a while (1400)
When I installed the tank, I couldn't get the pump to turn on-brain fart, I had hit the ign kill switch while installing the roll cage, lol
While looking for the trouble, I man. turned on the sec pump, which brought it up on pressure
Anyway, when I recycled the ign to start, it fired right up, but the pressure started dropping, so I hit the switch to fire the sec pump, which brought it back up to 43 PSI, then shut it off, then the pri pump was fine-maybe sitting dry for a while, the seals dried or something, but seems ok now
I have the sec. pump set to come on in boost, but also have it so I can man. turn it on, and man turn off the pri pump also
#70
Any new reviews on the 12-600 or 12-800? I am pretty sure my Bosch 044 is on the way out in my Monza, it's been making more noise lately and intermittently the car falls on its face about 8-10 psi into boost. I am running E85, but was told after the fact that the 044 wasn't E85 compatible. Oh well.
Afraid not dude, the -2 just means dual inlets.
https://www.holley.com/products/fuel...arts/12-1800-2
