Not enough compression?
Old Apr 18, 2013 | 02:22 PM
lemons12's Avatar
I agree.. That is why I put buddies numbers up. It surprised me when I saw his boost.
Im seeing the heads change, pick up a little power but still need to fix something else.
Exhaust?
Old Apr 18, 2013 | 02:46 PM
Sarg's Avatar
Can you post up the actual graph? To me it is a no brainer...toss a bit more boost at it is much cheaper than changing heads unless you are just flat out of compressor.
Old Apr 18, 2013 | 05:14 PM
ayousef's Avatar
what are the specs on the EPP blower cam, that will help you figure out what your dynamic compression ratio is, which is what you need to know if you're thinking of milling the heads.
Also, is the tune spot on? how many degrees of timing are you running and what dyno?
Old Apr 18, 2013 | 06:05 PM
never2low's Avatar
Don't think its out of compressor but not sure. Im 1100 mi away from the car for work for another month but I'll get my brother to get a count of cogs on the pulleys. It was on a dynojet and tuned by Andy Wicks of Dynotune. EPP's Blower cam - 232/240 .595''/.608 115 Ill have him get a picture of the graphs as well. The car has 1 7/8 tsp headers with their true dual 3in exhaust.
Old Apr 18, 2013 | 06:14 PM
never2low's Avatar
Oh the tune was not spot on but really close. He ran out of map sensor and quit there. Also not sure of the timing.
Old Apr 18, 2013 | 06:31 PM
TransAmatt99's Avatar
I know the feeling- spend a fortune and get disappointed when its done. I used an ls2 block and had a ton of blow-by, possibly cylinder expansion from the aluminum? I never found a true answer but I also had around 8.x-9 compression and the car stopped making power at 18#s. Either way its probably the same problem you have. Try the head swap and try again.
Old Apr 18, 2013 | 07:27 PM
never2low's Avatar
Yea it really makes a guy depressed...
Old Apr 18, 2013 | 08:37 PM
Sarg's Avatar
Ok no offense to this Andy guy, but if they put the car together, they should have known how much boost it was going to put down and had a map sensor ready and in there that could handle the boost...not only that, but they should have specced the tune accordingly and gone with the correct tunning OS.
At 18-19 psi you are at 32.7-33.7 psi absolute which means you will need a minimum of a 2.5 bar map sensor, but why not go with a 3 bar at that point and a 3 bar operating system and have some head room. Sounds like some crap to me, but then again I tend to plan a little over what I need...sorry rambling a bit, but sounds like you might be dealing with some BS.
Old Apr 19, 2013 | 07:33 AM
never2low's Avatar
Well I built whole car myself and it was intended to have the maf in it still but he could never get it run and drive halfway decent. So then he went to a 2 bar without the maf and its maxed out now. If I would have known the maf wouldn't have worked I wouldn't have spent the money on it and put the map in.
Old Apr 20, 2013 | 11:56 AM
never2low's Avatar
My brother spoke with Tony Mamo yesterday and he said I have the right head for the rest of my setup. He thinks there is a problem somewhere besides the compression and would like to see my graph as soon as my brother can get a pic of it for me.
Old Apr 21, 2013 | 01:42 AM
lemons12's Avatar
I'd be talking to Bob.
Old Apr 21, 2013 | 08:25 AM
  #32
Sarg's Avatar
Ok, makes a little more sense. I am sure you could sell off the MAF and pay for a 3 bar
