What oil are you guys running in your turbo cars??
#42
John deere plus 50 15-40w. you giys running rotella need to make the switch, deere oil is formulated as a offroad oil and has all the zinc a motor can stand.deere also has a great break in oil called break in plus 30w. you guys need to check it out.
#43
VR1 mix of 10-30 and 20-50
Why are some of you guys changing out your VR1 with less then 1000mi on it? Vr1 is fine up to 3000mi, depending on use and app, according to Valvoline themselves. Are you guys using the "Non Street Legal" version with no detergents? Because those are two different oils.
#45
For those dumping out their VR1 to early.
"We are not able to join the forums, but we can give you the answer you need, or maybe would like to add to the forum. Our VR1 Racing Oil is NOT just an "ordinary new car street oil" as listed. Our Valvoline VR1 Racing Oils can be used in street applications, but still contains the high amount of ZDDP (Zinc and Phosphorus). This information can be found on our Valvoline.com website, under the section where it lists the Racing Oils. We have also added the product information sheet for both the VR1 and the "Not Street Legal" Racing oils. As you will see, Valvoline still contains 1200 ppm Zinc content in our regular conventional VR1. It does carry the API Service "SM" rating, but this oil was not made to change for emission standards due to it not being a "ordinary street car oil." This information clearly states the amount of both the Zinc and Phosphorus levels in the oils. The main difference between the the "Not Street Legal" racing oil, or commonly known as Conventional and Synthetic Racing oils, and the VR1 is the Calcium content. Calcium levels are higher in the NSL oils, compared to the VR1, and the NSL oil is only recommended for 500 mile oil changes, while the VR1 is a 3 month/3,000 mile oil. Valvoline stands behind the flat-tappet and more aggressive type cam applications 100% with our Valvoline VR1 and NSL Racing oils. The proof is in our product information sheets, which are online for the viewing as well.
Here are the product information sheets with test results for all of VR1, Not Street Legal conventional, and Not Street Legal Synthetic.
"Adding to what we stated earlier, we have read throughout the forum. We see a lot of references to the API Service "SM" rating, being the main cause for catalytic converter damage. SM is basically just a gasoline rating. The S stands for Spark ignition, which refers to the ignition for gasoline type vehicles. When an oil has an SM rating, that just plainly means that the oil past the specific API (American Petroleum Institute) test requirements to obtain this specification. It has nothing to do with catalytic converters. The rating that stands out on conventional motor oils, (Premium conventional, Durablend, & Synpower) is the GF-3 and GF-4 ratings. These are energy conserving ratings that are necessary because of the Environmental Protection Agency mandating federal standards to further reduce emissions, beginning with '05 vehicles. These are the ratings that make the oil safe for catalyst effectiveness, and these ratings are not found on the VR1 Racing Oils due the ZDDP additive content, not API Service "SM."
Hope this helps,
Valvoline "
Hope this helps,
Valvoline "
#46
Hope this helps,
Valvoline "
Hope this helps,
Valvoline "
I personally have been running rotella 15-40 for 3 years now on my stock 100k mile ls1 with turbo. Been at 600+whp (more like 700 now through a th400 according to my et and trap speed) the whole time and gets beat like I'm trying to blow it up on a weekly basis.
#48
Some good info there.
#55
Rotella nonsynthetic 15W40 here.....running the same motor for 8+ years People can argue that there is better stuff out there, but it has almost twice the zinc and phosphorus as most of the top 10 oils in the wear tests. If its changed often it works great and is cheap.
#56
Thinking about changing my oil from Mobile 1 15-50 to Rotella any thoughts should I switch from a synthetic to non or stay synthetic ? 408 stroker lq4 block, s480 turbo.
#57
Seriously though, I like the little shell on the Rotella. Makes me feel like my engine is being lubricated with real dinosaurs. I use 15w-40 because I feel that 15 to 40# is good oil pressure at idle. 5w-30 is too low at 5# to 30#.
Maybe someone who actually knows something about oil should give you advice. lol.
