PROJECT RED ROCKET TUNING HAS STARTED! AES390, Twin turbo, 4l80e. PG21, Post 408! :)
#286
Wow man, hope the Tick cam helps. Mine is sitting in my garage and begging to be put in. I'm back home and starting back on my build. I am loving the time and effort you put into the painting. I wont even pretend to think mine will look as good.
#288
^ yes. Martin explained piece by piece why the cam isnt ideal. He said if you never would of called me, yiu would of been happy because the cam would sound likena race car and it would of made high peak hp. But he said torque would be down, there wouldnt b hardly any power under the curve and the turbos would spool very slow. He said my old cam had like 16* of overlap. My new cam has 4*.
#289
Martin told me this cam would be awesome for my setup so I believe him. I see a ton of people using his cams and they're happy with them. And thanks man. The painting is soaking up a lot of time but it needed to be done. Just take your time. Mine is far from perfect, I just did it thr best as I could. Get you a build thread started!
#290
Well, im pulling out this NA cam thats in this motor. 238/240 .605/.609 112LSA on a 109.5CL isnt boost friendly....at all.. im not sure why AES specd me this cam for my twin turbo setup, but ive had several people question me on the cam and even my self wondered about the amount of overlap. So i shot the specs over to Martin @ Tick performance and he said my cam is horrible for boost. I have a buddy picking up my old cam today and ill be ordering my new cam tonight from Martin. Looking at a 230/239 .609/.610 115+5LSA now. So just a little hiccup, but ill be assembling the new cam next weekend, then onto reinstalling all my cold/hot piping for final assembly. then its on to the wiring harness and starting this ****** up!
When I was at AES we ran this cam spec in 390ci multiple times, made great power and ET, why mess with success? How many times has your other cam spec been run, tested, proven? and in a 390? Did it go 5.20 to the 1/8?
Granted I would use less cam in a TBSS, but that wasn't my decision.
#291
I asked for a choppy idle at the expense of torque though. After taking out a high comp big cammed 434, I wanted the idle to be similar for that oldschool factor.
I'll be leaving mine in.
I may be wrong, but I think AES builds their motors and specs their cams etc for the strip. Not the dyno? Iunno. Every engine builder will give you different reasons for cam choices. Use what works.
#292
Martin said it would of made great peak power. And I probably wouldnt know that its not as efficient under the curve. This is a street car, not a drag car. So under the curve power is more important to me than peak power. And yea the car hasnt ran yet. I dont wanna get it completely together and running and have to tear everything apart the swap a cam. Might as well do it now. Everything ive read and have been told is that overlap is bad for turbos. That cam has ~15* of overlap, the new one has ~5. And I also asked for a specd cam for my motor based on what my heads flowed and the rest of the car.. It just seems like they just threw that cam into my motor cuz "thats what they use" and apprently they did cuz several other people have the same cam.
#293
wow, i'm not the only one with cam issues. I asked them like 8 times about the cam installed. i told them this is going into a 5000 lb vehicle that will be driven every day 3 seasons of the year, wanted low end tq, and no lopey idle. i recieved the opposite, has to idle at 1000 rpms, low vacuum, and choppy idle
If you'd like to talk cams my contact information is shown. Thanks.
#297
Just a little update. Ive started final assembly on the car a few days ago. i was going to wait until i had it mostly back together, at least the turbo kit before i updated the thread, but i didnt think many people were following this any way so i didnt. lol but heres how it sits currently..
