Detonation?????
Old May 8, 2013 | 08:50 PM
denmah's Avatar
Moderator
i have re used stock rod bolts all day long 7k rpm loves it
Old May 8, 2013 | 09:43 PM
Ashton233's Avatar
Originally Posted by Blackpanther99
Did you use the IMG code?
Haha...whats an img code? I really dont know what that is. I get to a point on photobucket where it says brows files but then it doesnt do anything.
Old May 8, 2013 | 10:06 PM
Ashton233's Avatar
Old May 8, 2013 | 11:21 PM
Exidous's Avatar
Are those dings or corrosion?
Old May 9, 2013 | 07:11 AM
Ashton233's Avatar
Dings/pits
Old May 9, 2013 | 07:41 AM
Blackpanther99's Avatar
Looks like detonation What fuel were you running?
Old May 9, 2013 | 09:50 AM
Ashton233's Avatar
Gonna guess just regular pump gas. The motor came out of an 03 Yukon with 70000 on it. Supposedly a lifter went out on it so the guy took it apart and then I got and wanted to rebuild it for a turbo. I figured with it already tore down I would learn a lot during the rebuild process. But keep running into little problems like the two bad pistons.
Old May 9, 2013 | 10:06 AM
HRHohio's Avatar
Looks like something made it's way into the chamber. I'd run some 200 grit sandpaper over the pits and then slap them back in. Looks good to me!
Old May 9, 2013 | 12:11 PM
MustangLS's Avatar
Was there any marks on the head? That looks like metal on metal contact.
Old May 9, 2013 | 12:34 PM
Ashton233's Avatar
No. Heads look fine. I would love to just use the piston but can barely afford to build this thing once let alone twice. And is it normal for the ball on the top or bottom of the pushrods to be bent a little bit?
Old May 9, 2013 | 02:19 PM
Sarg's Avatar
MustangLS and anyone else who was interested, those pistons and rods appear to have to wrist pins a little seized up. Pistons and rods appear fine, but seems some corrosion set in from not being in a climate controlled environment with not enough oil on them. If anyone wants them, they are yours, but I would hate to ship them out not knowing if that would work for you.
