My On3 Non AC Build
Old May 8, 2013 | 09:13 AM
Striker289's Avatar
Talking My On3 Non AC Build
Little Background, I have had my 2000 Trans Am since 2008. Bought it after my 1999 Trans Am was totaled after being Rear ended By a H2 Hummer. I always Wanted to do a turbo Build but funds would never allow it. I finally Bite the bullet this winter and started ordering parts. The motor needed all new Gaskets and I figured if I was going that far just go all the way.
Stock Long Block
LS6 Intake
FIC 60#(72# on My Fuel System) Injectors
Brain Tooley Springs
Summit Under Drive pulley(already had)
Manely Pushrods
WS6 Store Catch Can
SJM ABS Delete/Line lock
Lokar Throttle Cable to delete the TCS
Battery Relocation
LC-1 Wide Band(Already had)
On3 Performance Non AC kit(76mm Turbo, Turbo Blanket, Scavenging pump, 4" Intercooler)
HPTuners(already had)
AC Delete Panel, Kept Heat.
Summit Racing universal hoses
Griffen Radiator
Flex A lite Fans
Permacool Trans Cooler and Fan(Already had)
Performabuilt stage 3 4l60e with 4000 stall(Already had)
Racetronix 255 with harness
Before The Build
The Build
Tired of being harassed about my plate being mounted low.
New Tires hope to Install Tomorrow
I also picked up a 3.42 Rear to swap in this weekend, my 3.73s are just too much now. And I am waiting on Greg banish Tuning DVD so I can finish Dialing in the Car. Sorry some pictures are out of order. I hope to get some better Pictures this weekend. So far she is a beast. I haven't been able to get Traction, That's why I bought the Mickeys.
Old May 8, 2013 | 10:52 AM
damon0346's Avatar
looks good bro
Old May 8, 2013 | 11:24 AM
mikh338's Avatar
very nice work man, how is the on3 kit so far? i was very interested in this kit also
Old May 8, 2013 | 11:36 AM
Striker289's Avatar
I haven't driven too much yet. still dialing in the tune and its been raining. The kit seems nice. The real test will be next weeking at Cruising OC.
Old May 8, 2013 | 11:41 AM
mikh338's Avatar
i also really like what you did for the hvac delete plate. i deleted my a/c and want to keep my heat as well, all you did was cut out that hole for the lines to come thru i assume?
Old May 8, 2013 | 11:43 AM
Striker289's Avatar
I had to cut the HVAC Box Flush with the fire wall, Cut a passage for the air to flow and then fiber glassed that. Then cut a hole in the delete panel for the heater hoses. Its clean, Heat works Great. And access to the Spark plugs is great now. Theres a few write ups on the forum.
Old May 8, 2013 | 11:56 AM
akCamaross's Avatar
Doing a build similar to yours! Hope to check out your car in OC!!
Old May 8, 2013 | 12:35 PM
munn79ta's Avatar
whats your total cost with kit and all extras you needed?
Old May 8, 2013 | 12:53 PM
Striker289's Avatar
The kit with the bigger turbo, Pump, Bigger intercooler, and turbo blanket it 2500 Shipped. I've got close to 6 into the car now though during the build.
Old May 8, 2013 | 02:14 PM
munn79ta's Avatar
thats way better than what other sponsors on this site are charging!!!!!! that seems pretty fair for everything...
Old May 8, 2013 | 03:55 PM
30th t/a's Avatar
Nice build. looking forward to the results.
Old May 9, 2013 | 10:12 AM
munn79ta's Avatar
are you running stock fuel rails? are you running a regulator?
Old May 9, 2013 | 12:12 PM
Striker289's Avatar
Stock Rails, Stock Regulator. Plan on upgrading to a return system later.
Old May 10, 2013 | 06:31 AM
munn79ta's Avatar
cool man well hopefully when you get all the little things worked out you can post some videos. i have yet to find an actual on3 turbo kit on an fbody video anywhere...
Old May 10, 2013 | 07:59 AM
BMF_Racing's Avatar
Looking good. In for more updates as they come.
Old May 10, 2013 | 04:40 PM
MonmouthCtyLS7's Avatar
Looking real nice
Old May 28, 2013 | 04:44 PM
SILVERBIRD97's Avatar
UPDATE?
Old May 28, 2013 | 05:25 PM
BlwnLs1GTO's Avatar
Are you required to run front plates on vehicles there?
Where I live, you only need to run them IF you have the needed mounting hardware installed on it.
Old May 29, 2013 | 10:31 AM
Striker289's Avatar
Yes front tags are required. used to run it under the bumper but started getting harassed.
Not much for updates. It survived Cruising OC, Cranked the boost up to 10 Pounds. Big change going from 6 to 10 pounds. My Wideband stopped working by the end of that weekend, I think it has something to do with how close it is to the turbo. Need to get a new sensor and play with the tune some more, She is a bit fat at WOT. Might try to hit 75-80 drag way in a week or two.
Old May 29, 2013 | 07:43 PM
SmartOJ's Avatar
how bout a idle or drive video.........
