Be forwarned! 1150 Horsepower LS1 Inside!
I guess thats why we call Mike the mad scientistP.S I will be around to help push the car in trailor if you need me...
Mike and Steve's car was selected to feature the system initially and show it off at the races. I believe it is supposed to be avail by the end of this month.Cool features: uses all factory GM sensors! Only sensor that was changed was the MAP sensor (3 bar). No edist or anything else needed. Uses factory coils with no missing or cutting out. Has built-in two step. Can also control the 4L60E or 4L80E. I believe the basic box is around $2,000, and the tranny and a few other options are add-ons. Also logs everything on its own, so no need for ATAP or EFI live.
You can contact Kurt through PM...his user name is 427.
The dyno cell getting "dirty" is because the dyno cell "changes the air" about 6 times per minute. When I exceed 1000 hp it starts to put ex in the room. This can make the inlet air taint with ex. Mike and Steve's engine has its air inlet in the front on the pass side, this is where the fresh air enters our room. I don't think it was hurting this engine, if at all. I have run 1400 hp in that same cell.
If the engine "breaks" in two passes it will be because we wore it out on the dyno!!
Good luck Mike and Steve....
Kurt
My only question was how well do these manifolds flow. He he.. well i think we know now! Nice work guys!
-Jarrod
That is what makes this combo that much more impressive. The whole car for the most part has been pieced together by Mike and Steve in Mike's back yard garage. It has the potential to run low in the 8's for sure. The combo could support 1500hp with the right engine.
very nice job by those guys.
