TT LS2 need opinions
Old May 10, 2013 | 10:05 AM
yama450yfz's Avatar
Default TT LS2 need opinions
I will be taking my 05' Vette 6spd LS2 to the next level over the course of the next year. I have got in touch with Redline Motorsports in regards to a DKT turbo kit they are ironing out the kinks on. I will be most likely running DKT 6766's with e85. The goal will be 1000+rwhp on pump and much more on the corn. I am looking for opinions for my motor, it is a bone stock ls2 at the moment. I know I will be going forged to attain my goals I'm just not sure if I should go stroker or what would be the best complement to the TT set up. Any advice would be appreciated. Thanks, Ray
Old May 12, 2013 | 07:31 PM
runsfromdacops's Avatar
Twin 5858s would be much better matched to your goals.
6262s if you want 1200 or so
with the 6766s your just giving up spool time and gaining nothing is return
Old May 12, 2013 | 08:06 PM
Driftin_240sx's Avatar
TR6060 and rear end. Your 05 stuff will be launched into space first time it hooks up.
Old May 12, 2013 | 09:48 PM
kickassT/A's Avatar
Dtk 6266's would fit the bill better in my opinion.... 402 would be my choice.
Old May 12, 2013 | 10:00 PM
Blackpanther99's Avatar
I would stroke that motor up to a 402 which will make it easier to spool some twins.
Old May 13, 2013 | 05:46 PM
Toxic-Evo's Avatar
the DKT turbos are a hybrid turbo flange with a 1.06 AR. they make power like a t4 but spool like a t3
for 1000 wheel 6262's will get you there. and the 6266's will give you tons of room to grow.... pretty sure Devin has the c6z kit with the 6266's rated at 1200 plus. and there race kit with 6766's at 1450 plus.
Redline is a GREAT shop. call Howard down there and see what he has to say on motor and set up.
Old May 13, 2013 | 05:47 PM
Toxic-Evo's Avatar
quick little side note...... the 6766's spool pretty nice... I wonder if Inspector12 will jump in. he has a set.
Old May 13, 2013 | 08:56 PM
jridenour31's Avatar
No way I'd run 5858's if the goal is "much more than 1000rwhp." The 6766's will be fine.
Old May 13, 2013 | 09:54 PM
Toxic-Evo's Avatar
for sure take the 5862's off the table..
but i think 6766's is a bit much for 1000
DKT's shop car is a stock LS7. made 816/843 at 8.5 psi with 6266's.... so i think the 6266's will get just fine to 1000.
but to each there own.
Old May 13, 2013 | 10:07 PM
kickassT/A's Avatar
Tell you what, ill trade you my 6266's for the 67's, lol. Even have a 408 I can throw a different set of pistons in for you and you'll be set for 1k.
Old May 13, 2013 | 11:46 PM
Oh, they'll definitely get to 1000 but I'm not sure how far past that they'll go. Just depends on what his definition of "much more than 1000" is since he said that's what he's after eventually.
Old May 14, 2013 | 12:25 PM
Toxic-Evo's Avatar
well the 6766's have made 1400 plus to the wheels..... they flow 93lbs/min. the 6266's flow 80lbs/min
so...... i hope to god they will make 1200 plus. lol.
Old May 14, 2013 | 12:29 PM
Toxic-Evo's Avatar
dont like?????
Old May 14, 2013 | 03:09 PM
kickassT/A's Avatar
Haven't done anything with them other then get the housings polydyn coated, lol. Still waiting on a motor, but plan to max them out.
Old May 14, 2013 | 05:29 PM
yama450yfz's Avatar
RPM will be taking care of the rear end.
Old May 14, 2013 | 05:34 PM
yama450yfz's Avatar
I have decided to ramp up this build with a RHS 427 block. The 6766's will make more sense I have not ordered the turbo's yet Redline is still working out the bugs on the set ups.
