expectations...
Old May 30, 2013 | 08:18 PM
Sales@Tick's Avatar
Compression is going to be in the 9.6-9.8:1 range. Most likely a 15cc dish.
Old May 30, 2013 | 08:29 PM
I8UR4RD's Avatar
https://ls1tech.com/forums/forced-in...ck-2599-a.html
Old May 30, 2013 | 08:44 PM
Blackpanther99's Avatar
Alot of people will disagree with investing alot of money into a 5.3, its about what you want and how long to last. With a good tune you will be setup real good.
Old May 30, 2013 | 08:53 PM
And thats a good deal for the product offered.
Old May 30, 2013 | 10:56 PM
nastylx's Avatar
Hmmm worth thinkin over... idk
Old May 31, 2013 | 04:21 PM
Sales@Tick's Avatar
The 5.3 would make good power without going to a 383, but spool time will be decreased and it will take more boost to do so. Turbo will be at the same efficiency with either 15psi on a 383 or 25psi on a 325. Well not exactly, but very similar as the 96/88 wheel can easily support 383 cubic inches.
Old May 31, 2013 | 06:30 PM
nastylx's Avatar
Im stickin with the original 383 idea martin, you an i will be gettin to know each other i guess lol just dont rape the ol wallet to hard, lube is key lol
Old May 31, 2013 | 06:37 PM
allout06's Avatar
the word cheap stays as far away as possible from the word boost for some reason lol...
Old May 31, 2013 | 07:07 PM
jridenour31's Avatar
How, assuming everything is the same besides ci?
Old May 31, 2013 | 07:19 PM
nastylx's Avatar
Cheap isnt my concern, fast and reliable is the goal, which equals expensive
Old Jun 2, 2013 | 03:42 AM
Sales@Tick's Avatar
That should of read spool time will be increased going from the 383 c.i. to 325 c.i.
If that is what you were referring to.
Old Jun 2, 2013 | 07:53 PM
  #32
nastylx's Avatar
So smaller ci equals faster spool?
Old Jun 3, 2013 | 07:12 AM
  #33
nastylx's Avatar
Or are you saying the compression ration of the 325 will cause a faster spool
Old Jun 3, 2013 | 12:07 PM
  #34
No, he just misworded it. More cubes will spool faster.
Old Jun 3, 2013 | 01:07 PM
  #35
nastylx's Avatar
Thats what i thought, had me confused for a moment
Old Jun 3, 2013 | 03:23 PM
  #36
nastylx's Avatar
So the 5.3 stroked to 383 should spool s480 1.32ar just fine
Old Jun 3, 2013 | 04:57 PM
  #37
nastylx's Avatar
Also need to start thinkin of a converter
Old Jun 3, 2013 | 09:55 PM
  #38
A stock ci 5.3 will spool that turbo fine, the extra cubes will just spool it that much faster. You need a custom converter.
Old Jun 3, 2013 | 10:35 PM
  #39
itsslow98's Avatar
Correct me if Im wrong but Ive always been under the impression that Stroker motors arent ideal for big boosted power. Personally id do a 370 or even a 347.
Old Jun 4, 2013 | 06:53 AM
  #40
nastylx's Avatar
I plan to have one spec'd, an slow98 all the stroker turbo combos i've seen have been stout, look up bykrdood7 on youtube, his white 383 is insane
