expectations...
Old Jun 4, 2013 | 07:41 AM
  #41
pwrtrip75's Avatar
What size turbo is a S480? Isnt there a couple different sizes based on that same model/frame number?
Old Jun 4, 2013 | 08:08 AM
  #42
nastylx's Avatar
Originally Posted by itsslow98
Correct me if Im wrong but Ive always been under the impression that Stroker motors arent ideal for big boosted power. Personally id do a 370 or even a 347.
Plus more cubes= less boost needed which in turn = less stress on motor so it'll be more reliable and last longer
Old Jun 4, 2013 | 08:09 AM
  #43
nastylx's Avatar
The billet wheel 1.32ar t6 s480 that im going with is a 96/88 i believe
Old Jun 4, 2013 | 12:38 PM
  #44
jridenour31's Avatar
This is not true. More cubes means less rpm, not less boost.
Old Jun 4, 2013 | 12:43 PM
  #45
Sales@Tick's Avatar
You're totally wrong.
Boost is a measure of what the engine can consume. More cubes, consumes more=less boost. Less cubes, consumes less=more boost.
Less RPM? Have you ever heard of longer cam timing to gain that RPM back?
Please don't argue this point as you're incorrect.
Just an example so you understand this:
Class we race in, has many cars and engine sizes using the same exact turbo, turbine wheel and AR housing. The BWS476 T6 1.32 96mm turbine unit. One competitor has a 427, he makes 16-17psi. Another competitor has a 370, he makes 22-24psi. Another competitor has a 325 c.i. 5.3, he makes 27-28psi.
These cars are running as much boost as they possibly can and are not holding anything back. Now tell me why the larger engine has a lower boost reading? It in fact does not make less boost, it just has a larger engine which is consuming more of it so less pressure is left in the intake manifold where boost is measured.
Old Jun 4, 2013 | 03:23 PM
  #46
Are all of those running the same heads, cam, and intake? Didn't think so. How does a 383 have a greater ve than a 325 if the only difference is displacement? It doesn't.
Old Jun 4, 2013 | 07:03 PM
  #47
nastylx's Avatar
Hey martin just so im clear here, exactly what size is the s480 1.32ar t6? mm?
Old Jun 4, 2013 | 08:08 PM
  #48
Sales@Tick's Avatar
Why did I know you would say that about the combinations. Ignorance is bliss.
Lol the fact that you're even saying that a larger engine won't have a greater amount of ve than a smaller engine shows you have not one earthly clue what you're talking about. Greater cylinder fill is why the larger engine will have a higher ve given the same camshaft, heads and intake are being used. Of course you can have some pro stock engine that has a higher ve than a larger cube motor than it, but pro stock engines are not being discussed here.
I would professionally ask you to stop embarrassing yourself right now as you are totally out in left field on this.
80mm compressor 96mm turbine.
Old Jun 4, 2013 | 08:14 PM
  #49
allout06's Avatar
Isnt that like turbo 101? X size turbo will create less and less boost the more displacement you have? Didnt think id see anyone argue this point lol
Old Jun 4, 2013 | 08:19 PM
  #50
Sales@Tick's Avatar
I'm really trying to be polite and educate this gentleman, but it is quite elementary. I never thought someone would argue pump gas is better than E85 either.....
Old Jun 4, 2013 | 08:27 PM
  #51
allout06's Avatar
hahahahahahahaha i saw those posts! lmao. i wish it was more abundant around here . 93+meth for me... You prefer 100% or a mixutre? PM if youd like. dont wanna hijack
Old Jun 4, 2013 | 08:41 PM
  #52
LilJohn's Avatar
Ott308 has this exact setup..
That turbo will love the 4 inch arm....
Boost is nothing more than the difference in air mass output of the turbo amd air mass consumption of the engine...
Old Jun 4, 2013 | 08:46 PM
  #53
OK, so if all of those engines were using the exact same combination, besides displacement obviously, how different would the boost levels be? I'm not saying they'll be 100% identical, I just don't think they would have a 10psi spread like you mentioned earlier in the thread. There's no way it's that big a difference.
Old Jun 4, 2013 | 09:35 PM
  #54
nastylx's Avatar
Martin FTW! LOL
Old Jun 5, 2013 | 01:36 AM
  #55
LilJohn's Avatar
It is that big of a difference.... at least one... maybe two of the cars hes talking about cone out of my camp....dependson which 325 inch combo hes referencing..
Old Jun 5, 2013 | 08:12 AM
  #56
nastylx's Avatar
actually i wouldnt mind being hijacked to get the answer to that question
Old Jun 5, 2013 | 08:13 AM
  #57
nastylx's Avatar
What is he makin at the wheels?
Old Jun 5, 2013 | 08:30 AM
  #58
akCamaross's Avatar
Its all about the tuning.. You can build a fully built motor but without the correct tune you can cause detonation. Im doing a stock LQ4 6.0 short block with Minor engine mods and going to try to squeeze 750rwhp out of it with about 10-15 psi of boost. With the correct tune I should be able to do this. Same with you.. I know guys running tons of hp of those stock iron block 5.3's but those tunes on em are perfect. So best of luck to whatever you choose!
Old Jun 5, 2013 | 12:47 PM
  #59
Sales@Tick's Avatar
100% M1 for sure.
Exactly. Boost is measured in the intake manifold so whatever is left over that the engine cannot consume due to it's VE(directly related to engine size)that pressure will be registered in the intake giving us our boost measurement.
I honestly could not answer that question. It's very simple though sir, the larger the engine, the more air mass it consumes. The larger the cylinder head's intake valves, exhaust valves,intake runners and exhaust runners the more air mass it consumes. The larger the camshaft the more air mass it consumes. All of this registers as volumetric efficiency. The higher the VE the higher the amount of air mass consumed thus the less air mass that is left over registering as boost pressure in the intake manifold.
Correct. Phillips is the only one of yours I'm referencing. I'll have a customers 347 c.i. 3.903" x 3.622" x 6.125" engine with my custom solid roller in it soon for comparison as well.
I can answer that for John as I don't think Ott308 has ever had his car on the dyno. He races it a lot.
Old Jun 5, 2013 | 03:26 PM
  #60
nastylx's Avatar
Well damn lol
