Procharger surge valve/low boost?
If there is a adjustment screw, you want to start the car and pull the vac line off the bypass. It should close all the way with the vac disconnected. If its not adjust the screw untill there is no more air comming out and reconnect the vac line.
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Going by the pulley sizes I'm guessing this is a 6 rib setup with the small crank pulley.
Any p1 kit we do gets 10-12psi. You just detune timing a bit in the high rpm area. This way you get plenty of midrange power.
Never had an issue with the bypass valves. Is it hooked up to the correct vacuum source?
