ls9 in 5.3?
Old Jun 12, 2013 | 11:59 AM
lsxmalibu's Avatar
Originally Posted by exodus_gs1
Very nice, was with the turbo setup? And how far do these cam spin
yes turbo, 8psi, untuned, timing is locked at 16, needs valve springs and more fuel. should pull to 6500
Old Jun 12, 2013 | 12:18 PM
exodus_gs1's Avatar
O ok, I was about to **** if you made 430 with out the turbo haha. But cool im so ready to get my stuff ordered and at my door step haha. Thanks for all the help guys
Old Jun 12, 2013 | 12:27 PM
lsxmalibu's Avatar
its a low number for a turbo, but it flatlined so I have some issues to work on.
Old Jun 12, 2013 | 01:37 PM
exodus_gs1's Avatar
Ah I got cha...
So does anyone know the power band of the ls9 cam? Like where should I set the shift point?
Old Jun 13, 2013 | 08:44 AM
Thumpn's Avatar
Originally Posted by asb2106
Thumpn, please explain this 1k resistor if you wouldnt mind..
X2 on the resistor.
Originally Posted by NEVERTWOFAST
Also would like to know about the resistor. I have a problem with my tach not working after this cam swap. I switched the wires like I needed and still have a cam postion code.
I used a premade extension. Was PERFECT length, not an inch to spare, and works flawless
http://goo.gl/JwyJy
the new sensor works on a different voltage and pin configuration, This only applies if you don't use a pre-made extension! because the extension already has it done to it.
When you extend the wires for the new sensor you need to flip the 2 outside wires for the sensor and then add the 1k 1/4watt resistor across the 2 wires you just flipped.You can get the resistor at any radio shack, they run about $1.29 for a 5 pack.
Old Jun 13, 2013 | 08:47 AM
asb2106's Avatar
I had read about it, and knew wires had to be swapped, but I was unaware of the resistor.
Good info! Thanks for the share
**Ill check down my extension for resistors, didnt see any on it at first glance, but ill peel back some loom to check it out
Old Jun 13, 2013 | 09:55 AM
1nasty86's Avatar
Turd Gen Guy
What is the purpose of the resistor?
Old Jun 14, 2013 | 08:16 AM
Thumpn's Avatar
The Ls9 cam sensor works on a lower voltage range, the resistor is there to drop the voltage so the computer doesn't get false readings.
Old Jun 14, 2013 | 09:40 AM
exodus_gs1's Avatar
Does it matter I'm using a ls2 sensor?
