Budget/eBay head studs
Old Jun 26, 2013 | 05:16 PM
atomic 6's Avatar
I would be thinking that I better go with something that won't break on me, if I had EVER had a KMJ stud break on me. This is while torqueing it down to the, above recommended, 70 lbs torque.
Maybe I has just been lucky four times, but.....
I do know I have had an ARP SBC head bolt (brand new out of the package) break on the third torque sequence. While using their lube, and to their specs. When that happened I grabbed an old ARP bolt from an the old build and just used it to replace the new one that broke, after taking the whole F'in head back off to remove the broken ARP bolt piece.
The replacement had been used three times before, and that is the reason why we just bought a new set of ARP head bolts, it worked and is still working. Just because you think you are trying to "playing it safe" doesn't mean you are. Even with ARP, there are no guarantees, that you won't lift a head.
On the other side of this, you watch, now when the ProComp studs are restocked they are going to be at higher price than before.
They now know more people have confidence in them so they can charge more, but they will still be way under the ARPs price.
Old Jun 26, 2013 | 10:25 PM
SSmoken's Avatar
im going with the cheap studs as well. like the rest of you guys, i cant justify spending the same amount on studs as i did my motor.
Old Jun 26, 2013 | 11:41 PM
LT1RAY's Avatar
I have set installed that I bought from Alpher and they work great. 70 ftlb's on the final round.
Old Jun 27, 2013 | 12:25 AM
HRHohio's Avatar
I went to 80 on my final round with the moly lube.
I'd say that either have the chance to fail. I doubt the procomp's are "significantly" more prone to breaking than the ARP studs, under the conditions that 98% of the people who buy them use them. For those who are going for that 1200 rwhp, forged pistons/crank, $7k+ build, the extra $210 may make them feel better, but like Atomic said, there are no guarantees and you may still lift a head.
Old Jun 28, 2013 | 01:34 PM
DavidPHumes's Avatar
Just a warning - I ordered direct from Pro Comp... ordered the 02+ studs listed on their site... and received the 97-02 studs. Paid $35 for 2 day shipping and was planning on doing the studs and gaskets tomorrow morning... BUMMER!
It appears that their website is incorrect. PC2465 are the 97-02, PC2464 are the 02+. The website has the SKUs the other way.
They are out of the 02+ studs (which I think that by itself is a typo because I thought it was 04+?). Anyway, big bummer for me.
As has been said even though I have an L33 it's still just a junkyard motor. If I ever went forged I'd reconsider my stud choice, maybe - but if it works it works and I'm not going to argue. Especially for ~600WHP.
Old Jun 28, 2013 | 06:33 PM
3pedals's Avatar
I torqued my pro comps studs to 85 on the final pass, no trouble yet.
I subscribe to the adage: if you got a $600 motor, use $60 studs......
Old Jun 28, 2013 | 07:27 PM
knuts82's Avatar
On my procomp studs I went to 70lbs in a 3 step 30-50-70lbs with arp moly lube. Pushed the motor to 23psi and no problems yet.
Old Jun 28, 2013 | 08:52 PM
HRHohio's Avatar
Good enough for what I'm doing.
Old Jun 28, 2013 | 09:43 PM
RonSSNova's Avatar
Same here. Obviously they don't care to fix the issue, I have been waiting a month for the correct studs.
I pointed the error out in my email, spoke to them on the phone as well. Very helpful. Probably the web designer is long gone......
Ron
Old Jun 28, 2013 | 10:16 PM
offaxis's Avatar
Oh **** I ordered the pc2465 studs for my ls2
I guess they will be wrong if they ever show up. I'm waiting well over a week
Already.
Old Jul 7, 2013 | 11:52 AM
^yeah still haven't heard anything back from them... although I did call on 4PM on Friday and well, most of you probably know that very few people worked on Friday haha.
Old Jul 7, 2013 | 02:34 PM
  #32
Schraders's Avatar
I broke a Pro Comp at a final pass of 70 pounds. They told me 55 was the max. It took about 4 hours to dig the broken piece out of the block. Left hand bits, the whole nine yards.
Old Jul 7, 2013 | 03:09 PM
  #33
3pedals's Avatar
Did you use moly thread lube? That's a must
Old Jul 7, 2013 | 04:33 PM
  #34
fastcars95's Avatar
I'm looking for a set of studs myself. No luck anywhere.
ARP might be the only option right now.
Old Jul 7, 2013 | 08:15 PM
  #35
Wicked69's Avatar
I have used the KMJ studs three times and tq to 80lbs no problem. I did them dry. Oops. However, if worried about the price and quality u could use ARP head bolts at $178. Are the bolts good to around 20lbs of boost?
My studs have been usez three times now so I will probably get ARP head bolts since Pro Comp is out.
Old Jul 10, 2013 | 02:25 AM
  #36
jalper's Avatar
Restricted User
I have extra stud if someone needs one,
702 327 9907
Old Jul 10, 2013 | 07:13 AM
  #37
9sectruck's Avatar
Ebay still has sum, ship out early as the 16th
Old Jul 10, 2013 | 10:38 AM
  #38
Forcefed86's Avatar
I don’t know why people think using more torque on a fastner not rated for that torque will hold a head down better. Over torquing a stud to 80lbs that is rated for 50lbs will result in less clamping force. Going over the yield point of a fastner (max stretch point) will permanently deform the bolt and weaken the clamping force. (or just break)
I’m not saying the china studs are bad, or that 55lbs is the max they should be torqued. (probably a number they pulled out of their ***.) I’ve seen the original OEM TTY head bolts/head gaskets hold over 700hp without fail. So claiming 15psi on some china studs doesn’t seem like a great accomplishment to me.
Would be cool to see a machine shop with a bolt stretch gauge get some real info for us in these head studs. (all lengths) They’d have to make up some sort of rig to do it but it would be great information.
Old Jul 23, 2013 | 12:13 PM
  #39
Where do you see these? I don't see any equal length factory diameter studs on eBay.
Old Jul 23, 2013 | 12:30 PM
  #40
denmah's Avatar
Moderator
i wouldnt mind seeing this too,
we have also had 700hp cars with stock head bolts and gaskets
