compression
Old Apr 28, 2004 | 11:57 AM
byarddog's Avatar
Default compression
ok what is the best way to lower compression, and then what is the cheapest way. I am going to run about 5lb of boost and dont want to grenade the engine.
Old Apr 28, 2004 | 12:20 PM
HUGGER ORANGE SS's Avatar
With 5psi of boost on a good tune your motor will be just fine!!
Once to start getting in the 9 + range problems will crop up..
To answer your question though. Cheapest way. Buy a thicker set of Cometic Head gaskets. I'm running .067" Stock is .054". You can even go bigger than .067" but I would not reccomend it on a blown car. This is not the proper way to lower your compression. Dished out heads bigger than the LS1 heads, like the Aluminum 6.0L truck heads. Or get 9 to 1 pistons.
Good luck
Clint
MECHAM's Avatar
best way is probably getting pistons dished...
cheapest way...probably get 6.0L heads with 72cc - that should drop a stock LS1 to ~9.5 comp..add a cometic gasket at .067 and you are close to 9.0-9.3..dont quote on that gasket but i know .067 is the biggest suggested for a FI.
Old Apr 28, 2004 | 12:22 PM
MECHAM's Avatar
d@mn u clint!
Old Apr 28, 2004 | 12:52 PM
byarddog's Avatar
Default thanks
thanks guys, ill start looking fot 6l heads
