Stock longblock LS1 with F1R= 700whp.
#32
Ive tried a few things and nothing really works without serious work to the radiator. Even with a nice big k&n on the procharger hat I was only seeing 6psi. When I pulled the hat it made 15psi at 6k rpm. I put a screen on it and that limited it to 14 at 6000. Just leaned it out last night and raised the limiter to 7k. The weather man claims were getting a 90* cold front this coming week so I might put it back on the dyno to see.
Yes its still on stock headbolts.
Ill try get a video up sometime soon.
Thanks guys.
Thanks guys.
#34
UNDER PRESSURE MOD
Nice setup... I like the fuel setup... can you PM me where you got that from? It's how I want to run my setup. I like the black hoses.
Oh, and killer power. If I read correctly, you're running E85, which should help keep the motor together for a while considering it burns so much cooler.
#36
Its sd the card is just a fancy iat..
Here is 2-3-4 video from last week
http://static.photobucket.com/player...ps2cf1770f.mp4
This is Saturdays result of a 3-4 shift on street tires..
The splines on the axle were slightly bent too.
#37
Must've been some hooking street tires lol. My factory 10 bolt is gonna see that I'm sure. Cause in also at that boost level and going up lol. Slow shifts help save rearend lives lol.
#38
UNDER PRESSURE MOD
Again, maybe it's just the camera, but it sounds like it's missing.
#39
First off, sorry to see the rear get anihalated like that, but I guess that's to be expected with over 700rwhp on tap. Second, in your video, it sounds like the motor is breaking up, maybe it's just the mic on your camera, but I'd check your logs and see if you're getting knock or misfires, because it doesn't sound right.
