370ci pt88 .96ar dyno graphs
One truck mani and one fabricated manifold (to clear a/c) , 2.5" merge, 4" dump, 4" air to air IC...
9 Second Truck Club
Sounds sufficient , unless you have a bunch of cobbled up bends. I would run it and see how it does. As long as you are able to keep engine in the power range trap will reflect power shown. I have actually had lower rpm combos trap higher than higher rpm combos. Sometimes chassis dyno's can be missleading due to how it loads, tire slip etc. My truck makes pk power at 52-5500 rpm and has always had a strong trap vs other trucks of similar weight. It will run mid 140's with a T4 pt88 at 4800lbs.
hey man, you have any pics of your setup? whats the specs on your build? Dont see many 6 speeds running a pt88. Im doing a forged 5.3. 6 speed is at texas drivetrain now. Debating on a Pt7675 or a Pt88. Was worried the 88 might be a bit too laggy with a 6 speed.
any videos? Hows spool between shifts?
Build thread with some pics. https://ls1tech.com/forums/forced-in...-pg-5-7-a.html
With your engine i would guess a similarly spec'ed turbo would be very good and stay in the sweet spot for longer, although i wouldn't expect full boost under 4600-5000 rpm with your set up. And it is a blast with a 6 speed... Good luck and stay safe...
I wouldn't go with the PT88 just because of the sketchy workmanship, i had my brand new unit seize on my with less than 100 miles on it, plenty of oil feed and good drain, PTE's reply was "this unit is mainly designed for the buick grand national v6".
what were you at full boost by? what heads cam and intake were you running?
