1000whp intercooler???
Old Jul 14, 2013 | 02:50 AM
Matt00's Avatar
Cool 1000whp intercooler???
Lets hear some opinions on intercoolers that'll handle 1000whp!
Old Jul 14, 2013 | 07:40 AM
PRAY HRD's Avatar
i can't log my IAT's but i'm just running the ebay A2A on my kit and have been to 949rwhp @22 psi so far with nothing exotic, just stock heads with a truck manifold turbo kit and a blower specific cam. not at all max effort setup so i think they hold up great and can be had for as low as $100-$150 new/used in the classified section usually. i've seen them used in apps over 1000rwhp as well. this is the 31x12x4 with 3" in/out unit btw.
hope that helps.
Old Jul 14, 2013 | 03:39 PM
stevieturbo's Avatar
Just buy/make the biggest and best quality MF you can fit into your car. No cheap egay units at that level.
Old Jul 14, 2013 | 03:52 PM
PRAY HRD's Avatar
What he said! Because clearly there are no good examples on this site of them working to that power level. Furthermore, why spend only $150 when you can spend a minimum of $500.
Old Jul 14, 2013 | 04:49 PM
Matt00's Avatar
lol pray hrd you have a good point. Ive saw them up to 1k but if yours holds up to that then theres no sense in spending all that money. I plan on running around 700whp but I want to be safe on the power side in case I wanna go bigger. Thanks for the input guys.
Old Jul 14, 2013 | 04:54 PM
Matt00's Avatar
pray hrd who makes the one your running?
Old Jul 14, 2013 | 04:56 PM
They dont cool and they dont flow particularly well. Just because a meth system makes up for the cooling inadequacies doesnt get around the fact they are not good performers at that level.
You could make 1000hp with no intercooler, does it mean it is the best option, after all it's cheaper than even a cheap unit ?
And the OP hasnt stated what usage. Obviously a top notch cooler is of less importance on a car that only spends a few seconds at WOT like a drag car.
If it was a car that sees more high power usage, then of course a better cooler again becomes more important.
There are many cheap options people could make on their cars but dont for obvious reasons. This is simply another one. Yes a cheap unit might get you by, but is it the bst or most sensible option ?
Old Jul 14, 2013 | 05:40 PM
Matt00's Avatar
You have a point as well. I was planning on hitting the middle and getting a good brand while not breaking the bank. Trickflow makes a kit for my truck with piping and all and its 750.
Old Jul 14, 2013 | 05:57 PM
6point7s14's Avatar
We have a sbf that makes 1000whp and a LSX that makes 1100whp with eBay 4 inch a2a local
Old Jul 14, 2013 | 06:03 PM
Matt00's Avatar
Huron speed has a intercooler out of their t4 kit for around 225
Old Jul 14, 2013 | 06:17 PM
PRAY HRD's Avatar
its the typical crx racing unit. i Just got a meth kit and not because i needed it but because it was basically given to me ($100) so how could i pass that up? lol i'm at 700rwhp on 93 pump gas and 949 rwhp on 110. high compression setup and have had zero issues with it. they don't flow the 'best' but they sure aren't bad either. just saying, i've got absolutely no complaints with mine.
Old Jul 14, 2013 | 06:22 PM
Matt00's Avatar
Ya you got a great deal on that meth kit. Ill probably run a meth kit just to be on the safe side as well. I dont guess it could hurt anything. This is off topic but the hp difference between fuels is crazy! Im just hoping for 700whp but more is better lmao.
Old Jul 14, 2013 | 06:54 PM
PRAY HRD's Avatar
almost always is lol yea it was from a buddy of mine that went carb for his turbo setup and offered it to me for a price i couldn't pass up. if you can go E85, you'll need to worry about things a little less too. good luck man!
Old Jul 14, 2013 | 07:33 PM
Matt00's Avatar
Thanks guys!
Old Jul 14, 2013 | 07:35 PM
Wnts2Go10O's Avatar
treadstone performance makes quality intercoolers for VERY reasonable prices/
Old Jul 14, 2013 | 07:39 PM
stock48's Avatar
9 Second Truck Club
I went middle of the road here and got a Treadstone seems to be working ok.
Old Jul 14, 2013 | 08:20 PM
Matt00's Avatar
Ok. What sponsor on here carries them at a good price?
Old Jul 14, 2013 | 08:48 PM
Matt00's Avatar
Stock48 on your gmc, have you done any bottom end work on your engine? Also how many #'s of boost are you running?
Old Jul 14, 2013 | 10:58 PM
Taubr Unit's Avatar
I have a Treadstone cooler in mine also. Quality is really nice compared to my eBay one I had. It was $375 so for a little more I opted this route vs the eBay but for me specifically I couldn't justify a $1000 fabbed one.
Old Jul 14, 2013 | 11:30 PM
stock48's Avatar
9 Second Truck Club
GMC has a stock GM bottom and runs a little 3'' core Nelson intercooler only rated for 600 hp lol. Ran sig times on 20 psi but has had 25 put to several times. Treadstone on Car is a 3.5'' vertical flow was around 480$ iirc. The crossflow cores are cheaper but will not fit my car. I don't think treadstone is a sponsor. I'm happy with the I/c but they kinda jacked me around on the order so I don't like to talk them up too much. Same goes with turbonetics...
