Huron Speed Truck Manifold T4 Hotside 20% OFF SPECIAL!
1-week special, Now through Sunday, July 21, 2013 we are offering our Truck Manifold Turbo Kit "HOTSIDE" for 20% off, yes... 20% off, only for this one week!
Also, we will toss in a FREE Alternator Relocation Kit! No additional cost!
$799.99
Purchase Here:
http://shop.huronspeedproducts.com/L...it-hotside.htm
This is the hotside components of the Huron Speed LS1 Truck Manifold Turbo Kit. The hotside components are made to mate up to reverse mounted truck manifolds in a 98-02 LS1-powered F-body. Being a Truck Manifold set-up, you will have to lose your A/C, Low Oil Level sensor, and remove or lower the front sway bar. Relocating the alternator is needed and is not included, but optional with this kit. This kit was designed and is made for a Standard T4 Turbo with a 3" V-banded Exhaust Housing. All Components are 321 Stainless Steel, Tig Welded, and polished. This is for the hotside components only and this kit includes the following:
-321 Stainless, polished, Crossover pipe with T4 Turbo Flange and 38mm 2-bolt Wastegate Flange
-321 Stainless, polished, 3" V-Banded Down-Pipe with 3" V-Band at opposite end for easy building off of
-Gasket Kit including gaskets for all 4 connection points on the crossover pipe (2 truck manifold connections, turbo, and wastegate)
-*INCLUDED in this special - Alternator Relocation Kit
Common Turbos to bolt onto this kit are: Turbonetics TC76, Turbonetics TC78, Precision 7675, XSPower Stage 3 76mm.
***Want to add a Turbo, Wastegate, or BOV with your Hotside kit? Send me a PM for killer packaged pricing during this sale.
Sale only applies for Hotside kits!
![](http://i833.photobucket.com/albums/zz253/Oh-Check/Hotside1.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/F0B0FB7C-6E3B-4A73-BFCF-657D6187B3E9-6085-000008ED6CBE31AD-1.jpg)
$799.99
Purchase Here:
![](http://i833.photobucket.com/albums/zz253/Oh-Check/7C582CF7-8A59-4278-AD70-EE16C3991F23-6085-000008ED683B6EED-1.jpg)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
