Stock bottom end lq9 930whp 17psi 91mm garrett
Old 07-18-2013, 03:02 PM
  #41
gnx7's Avatar
If this motor is from an '02 Escalade.... how can it have LS2 style rods that weren't released yet?
Old 07-18-2013, 03:30 PM
  #42
HRHohio's Avatar
I wonder if it would be better if we called them "Gen IV, Floating Wrist Pin" style rods instead of "LS2" style rods. It's just easier for people to say "LS2" Style rods.
My understanding is that all LQ9s ('02+) came with "Gen IV, Floating Wrist Pin Style Rods" and LQ4s came with "Gen IV, Floating Wrist Pin Style Rods" after '04 or '05.
Old 07-18-2013, 03:35 PM
  #43
gnx7's Avatar
I just thought pre '04.5 LQ9s had flat top pistons with more compression with a small bump in power.
Old 07-18-2013, 04:57 PM
  #44
LS-Rx7's Avatar
I'm not positive in the year of the motor I was told it was a 02. The engine was a warranty engine from dealership and I got it from a buddy. I had the pan off the car but didn't pay attention to the rods or wrist pins. I wish someone that actually knows if my engine has ls2 style rods would speak up so this discussion about the rods will stop.
Old 07-18-2013, 05:43 PM
  #45
Blackpanther99's Avatar
Those rods though. jk...
Old 07-18-2013, 08:58 PM
  #46
GMCtrk's Avatar
Becauese "LS2 rods" is a misnomer. The LQ9 introduced for 02 model year did introduce the beefier bottom end. They are "LQ9 rods"
Old 07-18-2013, 09:46 PM
  #47
Zmg00camaross's Avatar
Who cares about the damn rods lmao. Stout numbers op
Old 07-19-2013, 04:00 AM
  #48
yelo04goat's Avatar
blow up $300 6.0 short block...
builds $4000 forged 370.......makes less power... hahaha... that would be my luck anyway.
sometimes i question why i built a motor... oh well
Old 07-19-2013, 08:36 AM
  #49
gallo-lo's Avatar
What' throttle body are you using? ?
Old 07-20-2013, 02:16 PM
  #50
LS-Rx7's Avatar
stock truck TB
Old 07-20-2013, 03:53 PM
  #51
LilJohn's Avatar
Need to find you a 1.00 housing for that thing...
Our luck thatd bring enough torque in earlier that itd cause reliability problems
Car had a nice sound at idle given the downpipe setup.
You did a great job on it man.
Old 07-20-2013, 05:22 PM
  #52
Indeed he did^ Very nice and simple setup with crazy power. Would love to see some 1/4 passes
Old 07-20-2013, 08:22 PM
  #53
fastcars95's Avatar
Another way to tell if it has the better rods is the exhaust manifold bolts.
LS2 style motors came with a 13mm bolt. I had a boosted 05 escalade motor in my Camaro. Its much stronger bottom then the LS1s
Old 07-20-2013, 08:40 PM
  #54
LS-Rx7's Avatar
I found a 1.23 housing.
Chris from Midwest turbo said it will lower my power band by 1000 rpms.
I have trouble building boost on the trans brake with the 1.39 housing
going to see how it acts at the track before I change anything
Old 07-20-2013, 10:50 PM
  #55
FlashLCD33's Avatar
Any pics or a build thread anywhere? I have an FC that is getting the turbo LSX treatment as well. Awesome numbers!! I'm curious how it'll hook and how you did your 8.8.
Old 07-21-2013, 12:13 AM
  #56
LS-Rx7's Avatar
Never did a build Thread I should have
The 8.8 is a bolt in granny's speedshop well u have to drill some holes for mounting but pretty much bolt in
It should hook at the track since the power comes in so late
Old 01-06-2014, 05:41 PM
  #57
coltboostin's Avatar
This car even make it to the track?
Old 01-06-2014, 06:45 PM
  #58
ATSMATT's Avatar
Hell that turbo is so lazy I wouldn't worry about the engine much. Make some power lower in the rpm range and it would start to be a concern.
Matt
Old 01-06-2014, 07:10 PM
  #59
bmr408's Avatar
wow nice numbers
Old 01-06-2014, 07:17 PM
  #60
bmr408's Avatar
kick a$$
Quick Reply: Stock bottom end lq9 930whp 17psi 91mm garrett
