Road Race Trans Am wanting turbo motor w/ pics
This is my friends Road Race-Trans Am style- Ford T-Bird with a 750HP 351ci motor that costs about $4k to rebuild every season.
We got to talking about the Twin Turbo LQ4 1968 Camaro that Im working on and the conversation went to "How do we make a Junk yard Motor last a season on a road course with adding a turbo to get close to the same power level and run on 93 fuel"
Can it be done?
what motor would you pick?
what turbo or turbos?
and use a blow thru carb.
what cam?
Can it be done?
what cam?
He runs "TT" (time-trials) & SU. mostly just races for fun about 10-20 times a year on all the West Coast Tracks like Willow springs, Button Willow,Spring Mountain, PRI, Cal Speedway, Las Vegas Motor Speedway... ECT.
Well Richard & myself are new to the turbo world so I've seen you state in other posts that every thing has to work together. So we are starting fresh and want to use a junkyard motor & a blow thru Carb, the care weights 2400# and has a 9" rear with a 4spd Jericho. it has 2" headers that wrap around the back of the motor to the passengers side door that has 2 mufflers and has lots of room for a turbo.
he wants to have the motor last a season or two.
So with this info can you do a cam, intake & turbo combo for this running on 91 pump gas . if you need more information let me know
Your gonna need to inject some methanol to live a season at 750hp on 91 octane. If you dont you will have to be really conservative on the timing and its going to be slugish.
ARP rod bolts/main studs/head studs/LS9 gaskets. I know 1/8 mile stock motors hold out really good but there not getting beat for long periods of time.
My vote is 4.8 for the shorter stroke should live a little longer turning higher RPM. There also easy to find and cheap if it lets go.
S475 with 83 mm turbine .90 A/R so it lights off fast.
Go with a cam from Martin seen several different cars/trucks sporting his stuff and they all work well.
Cool build by the way.
Just build it lower compression than the current high CR trend and it will be perfectly happy on the lower grade fuel.
It may require an extra psi or 2 of boost to meet the goals, but it will give a huge safety margin.
The following users liked this post:
Homer_Simpson (01-04-2022)
wow I like that 4.8 w/317 heads with ebay head studs & no methanol cuz he is running a carb.
Whatever happens be sure to keep this thread updated!
I would stick an intercooler in there just for the safety it adds. Yes you can get away with it on a carb, but its better to have lower intake temps.
Any reason for not going EFI and using the stock, or aftermarket, computer?
he tried some Australia guys EFI set-up and kept blowing up motors so he went back to a carb setup and hasn't had a problem so he like carbs. I might get him to switch over after he sees my TT DD Camaro with no issues. i think it was lack of support for the system he was running. i think he will go with a inter-cooler its cheep insurance.
but yes I agree truck flipped manifolds and a single turbo.
Stacey, Any reason for not going supaercharged? There are lots of 750+ bph cars out there on stock bottom ends these days. Pretty much a bolt on solution. Obviously you would need to get the computer working first though. Also the power delivery might be a little nicer for a high BHP rear drive car like that.
Just another option.
4.8 crank in a 6.0 block with L92 heads. You get the shorter stroke and rod/stroke ratio of the 4.8 for increased longevity and higher RPMs, but the larger bore increases it to around 5.3 liters overall. L92 heads and intake flow more than almost any other readily available head, power output should be phenomenal for such a small effort.
