Methanol/Water Injection Guys... Post your #'s
Motor: 5.3L
SCR: 9.5
Timing: ~13 deg (still working on raising it)
Fueling: 0.78 lambda
Mix: 50/50 water/meth
Flow rate: 15 gph max w/ dual nozzles, starts at 2psi, full at 12psi
Boost: 13psi max
Plugs: TR6 gapped at 0.028"
RWHP/TRQ:
Thanks!
2 10gph nozzles with progressive meth kit. 75/25 meth/water
670rwhp on dyno jet std correction 11psi
Have no new numbers with blower maxes out with wastegate setup. It sees 11psi and 16psi depending on what I need to beat lol
Picked up 48rwhp by adding the STS water/meth injection at 6.5psi on a 5lb spring on pump gas. 50/50
In process of installing new LS3 with the latest Aquamist HFS4 system so will have far better data and control for this one.
SCR: 9.1
Timing: 15 degrees
Mix: straight meth
Flow rate: dual nozzle alkycontrol kit
Boost: 19 psi
Car has been 9.25 at 153.3 with a footbrake 1.56 sixty foot. alot more left to go hoping to go back soon
i have the motor apart right now for a unrelated problem but every thing looks just like the day i put it together.
