427LSX - Procharger F1R - FMIC help
Ok guys I need some help with this lol.
I have a fully forged 427LS Bowtie block with Oliver Billet Rods, JE Pistons, Callies Racemaster Crank,AFR 230 72CC Heads, FAST 102, NW 102, running 9:1 compression and just bought a ProCharger F1R Supercharger, with the below COG kit. I will be buying the ProCharger BIG RED, and need suggestions on a FMIC.
COG Kit:
http://www.yellowbullet.com/forum/sh....php?p=7498230
The Car will run the Lonnies Dual 340 Pumps, Tick TR6060 Level 5 Trans with Spec PT Trim Twin Disk Clutch.
This is all in the car already:
Tick Master Cylinder, to a Ford 9" rear, with Spohn Chromoly RCA`s Double Adjustable, Spohn Chromoly Torque Arm with drive shaft loop, Chromoly Sub Frame Connectors (Custom), Spohn racing rear sway bar (Chromoly), and the radiator in the front will be moved forward as well (Griffin) with AN fittings. SLP Line locks are installed as of now as well as rear Koni SA shocks.So that's the build of the car so far....
What FMIC should I go with? I am looking for 900Wrhp and this is going to be driven on the road mostly...
Please let me know your thoughts![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks
COG Kit:
Thanks
