ls1 e85 and boost problems
Old Aug 28, 2013 | 05:29 AM
enroh's Avatar
Default ls1 e85 and boost problems
Hey guys,
Posting from australia here.
I have a turbo ls1 running on e85 and I am having problems with it stalling when in gear and initially cracking the throttle. It will do this when taking off or when coasting at any speed and applying throttle. It will also stall at idle sometimes when climate control kicks in but my biggest issue is trying to take off at intersections...lol
It is a 01 ls1 standard motor standard cam. Gt45 bush bearing turbo. 1015cc Bosch injectors and is tuned using hp tuners. It made 500rwhp through a stock 4l60e and 3.45 LSD.
I'm currently running heat range 7 ngk plugs.
Any helpful ideas would be great.
Regards josh
Old Aug 28, 2013 | 05:47 AM
ittwgn's Avatar
tuner had experience with turbo e85 ??
Old Aug 28, 2013 | 05:57 AM
enroh's Avatar
Yes he has had alot, I've only just got it back from him and now can't even call him because he's gone holidaying, otherwise I'd just be calling him to fix it.
I need to get it sorted as in 7days I've got a big car meet and need it running properly.
Anything above Opening throttle and it runs great and pulls really hard, its got a great torque curve.
too.
I don't suspect it is in the tune, though I'm not ruling that out, I'm wondering if it may be something else. I do have access to hp tuners to change things myself if I need to.
Old Aug 28, 2013 | 06:20 AM
LS1 240sx's Avatar
Can we get a look at your tune, also can you log this stutter through scanner. I had this problem before.
Old Aug 28, 2013 | 06:46 AM
enroh's Avatar
I can upload the log once my laptop starts to like me again.
What ended up being the problem with yours 'ls1240'?
Old Aug 28, 2013 | 04:01 PM
enroh's Avatar
here is the log
in this run it only completely stalled once i think but came very close frequently.
File Type: hpl
Old Aug 29, 2013 | 03:35 AM
enroh's Avatar
Could fuel pressure be an issue?
I'm running a 1:1 rising rate high quality fuel regulator connected to manifold behind t/b so that it gets both vacuum and boost.
Static pressure is 60psi, however that drops to 50@idle due to vacuum. When throttle is cracked vacuum drops suddenly and pressure snaps back to static then comes back sown as vacuum builds again.
Could this be an issue?
Old Sep 4, 2013 | 04:42 PM
enroh's Avatar
Any ideas guys??? Really need to get this sorted. What appears to be happening is the ecu is pulling 20% fuel out at idle and then as you accelerate it leans out considerably and stalls. Thing is if you take fuel outta the table it will not run at all. When I disable o2 sensors and it doesn't trim fuel if anything its little worse....
