*My Build - Huron Speed l Tick Cam l 5.3 l 75mm l E85 l 700hp *
LS1Tech Sponsor
There is no issue to worry about. If you are experiencing any boost creep and running the wg adapter, I would recommend removing that and putting the flange closer to the merge and that should solve your issue! We can assist with this as well if you need it, but nothing major at all to worry about
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I had boost creep issues as well. I really like the custom merge, that's how they should come.
https://ls1tech.com/forums/forced-in...ost-creep.html
LS1Tech Sponsor
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
