Baddest small-size T4 turbo out there? Want to upgrade my TC78
#41
The S400's in T4 flange are all the same size as the pictures above. So its a tad bigger then the 7675.
#42
Have anyone seen drawing of PT7675 and PT8847? I've realized that distance from center of exhaust flange to the shaft plane is important to me because if it's more than 2.50" (on TC78 and T7875), that will position whole turbo even closer to the pulley... But I can't find drawings of PT stuff
This drawing shows what I mean:
http://www.turboneticsinc.com/sites/...RIES_TURBO.pdf
#45
If you are settling on that size the Turbonetics version can be had for less than the standard cast journal bearing pt7675. It comes with the billet wheel and ceramic ball bearing cartridge as well.
#46
Thank you for clarifying that for me. I appreciate it. Might be in touch with you come Winter about purchasing. Sorry for filling your thread with a bit of off topic stuff, OP. *end thread hijack*
#53
#54
#55
No, I'm looking for this distance I've circled in red.
My exh flange is almost horizontal so this distance is what determines how close to the engine will move the whole turbo, and whether compressor cover will fit.
If it's more than 2.50", turbo will sit closer to the engine.
#57
What are other good turbos close to PT8847 in size but make more power (and preferably not costing $2200)?
I see a point in modifying piping slightly for some gains BUT for small gains of 8847 over 7675, and price tag of 8847, it's not sensible in my opinion...
