WS6 Rear Mounted Radiator (UPDATE!!! COMPLETE AND TESTING) MANY PICS INSIDE!!!
Old 09-06-2013, 03:40 PM
Cam72aro's Avatar
Sounds good. I admire you for doing this and documenting it. I hope it works, and if so I will do it also.
Old 09-06-2013, 03:42 PM
Jwilliams04's Avatar
Hope this works so I can change my setup.
Old 09-06-2013, 03:45 PM
mrstepheneades's Avatar
Probably could stand to run smaller piping but that's what is lying around the shop so im using it.
Old 09-07-2013, 05:56 AM
Well I got a little more done last night. Got the pipes made going to the rear. Trying to find all the little straight pieces I can lying around to get two 68" pieces lol.
All TIG'd together
This assembly will have 3 straight pipe couplings per pipe. To make it a little more simple to install and remove.
Will also have a air bleeder and a hose connection for steam ports from heads.
Old 09-07-2013, 04:41 PM
Preston99WS6's Avatar
For the steam line I would suggest you drill and tap the flat spot on the top of the water pump. 1/4 NPT tap you probably have one or a friend that does and Male air compressor fitting should be 2 dollars tops.
Benefits- Less hose=more reliable, and less clutter in the bay.
Old 09-07-2013, 07:31 PM
Busa_rob's Avatar
In for pics.
Old 09-07-2013, 07:42 PM
Steam vent is in top water pump piping. Got a lot of pics to upload when I get to a computer. Pipes have made it to the rear now. But not over the rear yet lol. Had to pressure test all I've welded so far to make sure there were no leaks.
Old 09-07-2013, 07:51 PM
Coal Mining Director
onfire's Avatar
Stock fans will not be enough to cool it. Neat project. Good luck.
Old 09-07-2013, 08:18 PM
Cam72aro's Avatar
I am curious to see if they will. I think they will. You are increasing capacity by at least 2 gallons, so that is on your side.
Old 09-07-2013, 09:04 PM
Stock fans will be pulling again like factory. And I may have a free aluminum radiator coming my way. Stock fans pull like 4000 cfm I think I heard. How much more is there to get lol...
Old 09-08-2013, 03:43 AM
chuntington101's Avatar
Great work! Can't wait to see the results. And plans on fitting a larger intercooler with all the room you will have up front?
On the air flow, don't forget the think about the air exit. It's just as important as getting air to the rad. DON'T FIT MESH ON THE EXIT as it will massively restrict flow. Watch where you are pulling the cold air from. Make surely exhaust components are insulated (wrap and heat shield) to reduce heating if ambient air. Have you thought about pulling air from the rear wheel area? Nice high presure zone with relatively cool air.
Be intresting to see how the stock fans cope. Are you going to be running them flat out all the time? Suppose you could just run one perminently and the second if temps rise.
Old 09-08-2013, 04:05 AM
  #32
Just curious why not run tubing down instead of piping. Really hope this works for you. I just starting my turbo setup on my G35 with 402 LS2 and have no room at all. This would help a lot. Good Luck
Old 09-08-2013, 08:32 AM
  #33
Fans will run as they do from factory. Low speed then high as temps rise. I have no exhaust in rear it exits out the front bumper so there is zero heat in the rear. No plans for bigger intercooler at moment. Maybe an idea for the future though lol.
Old 09-08-2013, 08:46 AM
  #34
LS1-IROC's Avatar
Aren't you supposed to use 2 different size pipes to ensure a pressure differential to keep the pump working correctly? Kinda like the factory does with the heater circuit?
Old 09-08-2013, 10:27 AM
  #35
Off road guys use same size piping. Factory is 1.25 and 1.5 on radiator hoses.
Old 09-09-2013, 07:59 AM
  #36
Here are some updates from the weekend. I was lucky enough to pick up a new aluminum radiator for basically free through a friend to make this job a little cleaner and nicer. Gonna start mounting the radiator and fans today so I can finish running the tubing up and over the rear where it needs to be.
All lines have been pressure tested with compressed air to 30psi.
Pipes are not bolted up or tied together yet. Just hanging in place for mock up!
Clamp is just for mock up. Wont be on there when I finish.
Old 09-09-2013, 08:27 AM
  #37
texas94z's Avatar
Cool design. What water pump are you going to run?
Old 09-09-2013, 08:30 AM
  #38
Going to see if the stock one will hang. If not I will add a equal inline pump in the rear if this doesn't work. Trail and Error!! lol
Old 09-09-2013, 08:33 AM
  #39
LS1Tech Sponsor
Slowhawk's Avatar
I like the thought process.
I would of just pushed the intercooler forward more, put in a 2 core radiator with an aftermarket puller fan and 1 pusher. We do this a lot and never have overheating issue's, even on 100 degree days they run 195 and under.
Old 09-09-2013, 08:46 AM
  #40
texas94z's Avatar
I think the length of the feed and return lines will cause a significant load on the water pump and the serpentine system. A remote electric water pump would be a great investment for your design.
Quick Reply: WS6 Rear Mounted Radiator (UPDATE!!! COMPLETE AND TESTING) MANY PICS INSIDE!!!
