WS6 Rear Mounted Radiator (UPDATE!!! COMPLETE AND TESTING) MANY PICS INSIDE!!!
#62
Thanks man, I got the radiator hoses actually hooked to the radiator tonight and bolted and supported under the car. Just need to make sheet metal cover for top support of radiator and bolt fans secure and wire them and I'm done.
Pictures from tonight in the am.....
#63
i wouldnt really be too worried about bleeding the air. just keep the rad cap off and fill the rad and as much as the lines as possible then fill your block from the upper rad hose port then run the vehicle with the rad cap off. once the t stat opens it will probably bubble alot then just add rad fluid as it idles to top it off while its still circulating.
#66
#67
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#68
Pressure testing for leaks in my wife's water for the horses lol
![](https://ls1tech.com/forums/picture.php?albumid=29578&pictureid=104418)
Tabs to hold hoses off manifolds and close to body
![](https://ls1tech.com/forums/picture.php?albumid=29578&pictureid=104419)
![](https://ls1tech.com/forums/picture.php?albumid=29578&pictureid=104420)
Connection tabs welded in to hold the long sections together
![](https://ls1tech.com/forums/picture.php?albumid=29578&pictureid=104421)
![](https://ls1tech.com/forums/picture.php?albumid=29578&pictureid=104422)
![](https://ls1tech.com/forums/picture.php?albumid=29578&pictureid=104423)
Mounting to cross member bolt behind transmission above driveshaft
![](https://ls1tech.com/forums/picture.php?albumid=29578&pictureid=104424)
![](https://ls1tech.com/forums/picture.php?albumid=29578&pictureid=104425)
![](https://ls1tech.com/forums/picture.php?albumid=29578&pictureid=104426)
![](https://ls1tech.com/forums/picture.php?albumid=29578&pictureid=104427)
![](https://ls1tech.com/forums/picture.php?albumid=29608&pictureid=104428)
![](https://ls1tech.com/forums/picture.php?albumid=29608&pictureid=104429)
![](https://ls1tech.com/forums/picture.php?albumid=29608&pictureid=104430)
![](https://ls1tech.com/forums/picture.php?albumid=29608&pictureid=104431)
This shows how it will be separated from the interior, plus it will have sheet metal cover over the radiator and fans later on
![](https://ls1tech.com/forums/picture.php?albumid=29608&pictureid=104432)
#72
