WS6 Rear Mounted Radiator (UPDATE!!! COMPLETE AND TESTING) MANY PICS INSIDE!!!
#122
It didn't after I cut hole out bigger for the fans there at the end before I put it back up front. Before I cut the hole bigger it was like somebody had a kerosene space heater blowing right on your back inside the car. My wife was literally trying to climb out the window like a dog riding down the road with half his body hung out the window. Was probably 100 deg in the cab lol. That's when I knew I had to cut holes for fans bigger lol.
#123
Get some smoke pellets and run the fans and test to see where the air is going. also ifs the radiator fully shrouded or is it just sitting in there? Also it would be interesting to see what the airflow is like under the car. I have heard that some cars the air flow actually reverses in some locations!.....
#124
#125
Race your car!
Op how did this work out, would laying a radiator down under the t top well, if it was removed and flat sheet metal’ed over work out better?
alum tubing instead of stainless would save weight and the heat conductivity would also help remove a ton of heat I would think too... just a thought.
thinking about doing this with my drag only car...
