HP numbers before FI
Old May 3, 2004 | 07:25 PM
Ralphy g-Machine's Avatar
Default HP numbers before FI
Hey guys,
Anyone want to give me a rough idea on what kind of numbers I can expect from this setup, before I throw on the D1SC? Some other questions, too.
Forged bottom end 346-350CI(depends on builder and options)(probably custom pistons to bring CR down to 8.5:1)
Stage II 6.0L Heads (not sure on builder)
Blower Cam (Whatever is most blower friendly, that my builder recommends)
LS6 intake (Should I go FAST w/ 90mm TB, is it worth the $900?)
Ported T/B
Ported Oil Pump
50lb/hr injectors
Chromolly push rods(Don't want to bend the stock ones with missed shift)
All bolt ons
Shorty/intermediate headers(they're kinda inbetween)
That's basically all I can think of right now. Pretty much the only thing on this engine that will be stock, is the block, and possibly the LS6 intake.
Thanks in advance,
Ralph
P.S. This is going in my pro-touring 68 Camaro, I'm hoping to run about 12-14psi of boost when I go FI (shortly after it's on the road) and am aiming for 600-650rwhp.
Old May 3, 2004 | 07:40 PM
PurEvl's Avatar
I got about 430 then 600ish at 8 psi
Old May 3, 2004 | 08:44 PM
WHOA! 430? I Was thinking more like 370, and that I was going to have to run mega boost like 14psi to see 650ish...guess I underestimated the power of the almighty LS1 LS1
Old May 3, 2004 | 08:50 PM
PurEvl's Avatar
well I run a big cam compared to most in here. over 230 duration and 600 lift
also have an lsx intake
Old May 3, 2004 | 09:21 PM
BIGBOS's Avatar
I think my motor would make 350-360 through the tranny setup, I have a really small cam
I'm hoping for 600rwhp + on 15-17psi through the D-1SC
Old May 3, 2004 | 11:50 PM
Crunch's Avatar
Low compression 346ci with heads and cam should be just under 400RWHP.
You will lose about 15-30HP by going low compression (depending on how much compression you dropped).
So subtract that from your average heads and cam setup (400-425RWHP), and that takes you to around 370 to 395.
But don't worry, the blower wil MORE than make up for that.
Old May 4, 2004 | 11:37 AM
5-liter-eater..do you have the LSX with the 78 or 90 mm TB?
Big Bos, damn you're a brave man! 17psi of boost, is alot
Crunch, 370-395 is what I had in mind, and is what I was hoping for...at around 3200lbs w/ me in the car, it will still be decently quick, even with the 2:73's or 3:23's (haven't decided yet) but once the blower goes in and the boost gets turned up
Old May 4, 2004 | 11:44 AM
PurEvl's Avatar
78 lsx with stock TB ported...like I said with low compression I still made 420-430 rwhp. But Im a 6 speed and didnt go the little cam route. My car still gets 18-20 mpg idles fine and has ac.
Old May 4, 2004 | 12:07 PM
BIGBOS's Avatar
Yea, I know the motor is good and my fuel is good, its the belt holding up thats always been my problem
Old May 4, 2004 | 12:09 PM
MIGHTYMOUSE's Avatar
my motor made @ 330 NA and 775 16psi later
my heads are not high dollar and my cam is 226/224 .523/.510 115*
all you need is a strong bottom end, let the boost do the work.
