Afr drop of 3points with dual nozzle meth, normal?
Old Sep 26, 2013 | 07:31 AM
SPRAYED 01's Avatar
Default Afr drop of 3points with dual nozzle meth, normal?
Running dual 15s alky control. With the initial pump pressure very low and 10psi turn on and 20psi boost I go from 12.9 afr to 11.2.
Julio does not suggest such a low turn on. If i put it at the 12 o'clock position its in the low 10s.
I have no meth under 11psi and if I were to put it back down to 5psi turn on it would go 9s afr.
Car puts down 900whp, ive seen guys with less and the same nozzle.
Is this too much nozzle or is it normal to literally have to command like 13.5 afr to get 11.0afr with meth?
Old Sep 26, 2013 | 08:01 AM
Realcanuk's Avatar
Julio knows his stuff and I'd listen to him. You want the meth to come on earlier than 10 psi for sure. I think you just have too much nozzle. I just went from a 15 and 10, to a 15 ad 5, and may even step down again. It was loading up at full throttle and getting too rich.
Old Sep 26, 2013 | 10:06 AM
SPRAYED 01's Avatar
Ya he does know his stuff, just wanted to hear from others to see if their dual nozzle kits act the same. I know combos make a difference too
Old Sep 26, 2013 | 03:17 PM
Martin718's Avatar
what is the purpose of your meth? are you using it for fuel or for cooling?
what fuel are you running?
i can prob help you but need more info, Julio has schooled me well
Old Sep 26, 2013 | 03:26 PM
Ferocity02's Avatar
I have mine set to come on at ~2psi to cut down on the delay, but I'm only running 15 gph total and it's 50/50 water/meth.
Old Sep 26, 2013 | 04:21 PM
SPRAYED 01's Avatar
Im using 93 octane and the meth. Its purpose is ti replace having to mix in c16 when i want to go over 10psi. I run 20psi at the track.
Old Sep 26, 2013 | 04:38 PM
Slowhawk's Avatar
LS1Tech Sponsor
If you use it like a fuel, then tune as part of the fuel system. I'll always dial the VE table with the meth spraying. I never/ever touch the PE table. Alky controls kit is very consistant on delivery.
For 20 psi I'll ramp it at 6-8psi.
Old Sep 26, 2013 | 05:04 PM
Martin718's Avatar
What is the gain set @? Also what kind of power? Whats happening is the fuel is more than needed and you are going rich, are you getting spark knock? Also your a/f value will be diff when at wot on meth mix vs pump gas straight. I ran a similar setup with 1 m15 nozzle and pump gas. Is e85 readily available to you?
Old Sep 26, 2013 | 05:59 PM
smokeshow's Avatar
Once you start putting that much supplemental fuel in it, regardless whether or not you just want it there for the cooling purposes...you have to pull fuel back in the tune. On aggressive big turbo setups I command stoich all the time. Meth takes care of all of the enrichment. Would the engine blow up if the meth quit working? Unfortunately, yes. But if you are working with a stock PCM, that's what you've got to do. Take extra care to filter your methanol, though. With a setup that is reliant on the methanol to make power and stay alive, you can't afford for debris to be getting in the tank and clogging up the nozzles.
Old Sep 26, 2013 | 06:00 PM
SPRAYED 01's Avatar
Gain was at 5,it made 902whp.
I can do e85 but made the decision to do meth instead.
Old Sep 26, 2013 | 06:14 PM
SPRAYED 01's Avatar
Slowhawk, that's exactly how I want to do it. The tuner yesterday changed some ve but made the pe and be command 12.8 afr to get to 11.2. I didn't like that at all. With no meth in the lower boost range its at 12.8afr, not cool.
At this point im going to go back to my non meth tune and use c16 to go to the track saturday. Ive been trying to learn how to tune on a 900whp as my first and wasted a lot of money on the dyno.
Il study up this winter and get back at this meth thing next year.
Old Sep 26, 2013 | 08:39 PM
Nitroused383's Avatar
Jake there are several safety features you can setup to prevent engine failure if your meth injection quits. I've setup several cars like this and have had meth pumps quit with out harming the engine at all. Just like slowhawk said you need to tune the meth as part of your ve. With as much meth as you're spraying even if it did quit I doubt you would hurt anything as it would go so lean once its tuned to equal your commanded afr.
Old Sep 27, 2013 | 02:10 AM
smokeshow's Avatar
Stoich is still rich enough to really **** stuff up. Usually 15.5:1 and higher is that safer zone where there isn't enough energy from the fuel to crack pistons, etc..
I am aware of several 'methods' people use to try to prevent damage in the event of meth failure, but none that I would trust to react fast enough or work properly in the event of a failure.
Old Sep 27, 2013 | 02:34 PM
Slowhawk's Avatar
LS1Tech Sponsor
The way I tune my cars is in OLSD. It's all off the VE table. Turn the meth to what you want and dial the VE table till it's at the commanded A/F at each boost level. Pretty simple to do.
As for meth dying. Well mine did on a 1000rwhp dyno pull (my pulls are timed 12 seconds on load). When putting the car together I put the meth kit on a 7 amp fuse and forgot. Since my tune is made with the IAT, when the meth failed it pulled timing and added fuel to the point the car stumbled bad. Didn't hurt anything. That was 30 passes ago.
Old Sep 27, 2013 | 02:40 PM
mrstepheneades's Avatar
Mine is commanded 11.0 and with twin 10lb nozzles and pure meth it drops to 10.2. Spraying it 7psi thru 16psi. Not been tuned on meth though. I added myself when I got a wideband to monitor AFR.
Old Sep 27, 2013 | 03:14 PM
Slowhawk's Avatar
LS1Tech Sponsor
If you leaned it out to 11.2-11.5 you would gain a lot of power though.
Old Sep 27, 2013 | 06:14 PM
I realize this lol but I'm to cheap to go back and my luck it will pop if leaned out. I beat on it every time I drive it and it has been very reliable so far. Just don't want to push my luck trying to get any more out of it. I'm going to see what makes next Saturday at Ticks customer appreciation day. What it makes is what makes lol.
Old Sep 27, 2013 | 06:54 PM
SPRAYED 01's Avatar
Im really surprised its only lowering it .8 afr. Is it an alky control kit? What are the pac settings at if so?
Old Sep 27, 2013 | 09:37 PM
Its the AIS trunk mount kit. No progressive controller. All or nothing lol.
Old Sep 28, 2013 | 08:30 AM
Monte4ever's Avatar
Good read here. I'm trying to dial in a 50/50 mix to help with my high IATs (180+) in the 1/4. Slowhawk, I would love to know more about how you setup your "safety features". I know which tables you're referring to but I would like to here from someone who has done it. I am also running the AIS trunk mount kit boost referenced - "all or nothing".
