cold side piping
Old Oct 21, 2013 | 08:05 PM
wes96z's Avatar
Default cold side piping
I have a kytp 76mm truck manifold kit i bought years ago and am just now getting ready to start my project, first thing I noticed I was shorted a piece to the cold side piping (too bad that company is not around anymore) but more importantly I noticed the cold side piping was not bead rolled. Is this common practice? should I have the piping bead rolled? If I dont will the couplers blow off under boost?
Old Oct 21, 2013 | 10:10 PM
ws602's Avatar
Just get some one to weld a bead around the pipe
Old Oct 22, 2013 | 05:03 AM
samdogmx's Avatar
try it you might get away with it.
I have seen 21 psi with no bead rolled pipes & haven't blown one yet, but my charge pipe is very short with no 90 degree turns.
Old Oct 22, 2013 | 07:08 AM
allout06's Avatar
Seen people use hair spray on the pipe before they slide it into the coupler. You can make your own bead roller out of a "u style" exhaust clamp, a washer and a pair of vice grips.
Old Oct 22, 2013 | 07:51 AM
MUSTANGBRKR02's Avatar
Or you can make tiny slices and bend or flare the ends out.
Old Oct 22, 2013 | 08:30 AM
Tally TransAm's Avatar
$4 aluminum pipe bead roller
Old Oct 22, 2013 | 09:12 AM
usdmholden's Avatar
Are those a pair of pliers that were modified? Or can you provide a link to buy a set?
If you made them, nice job. I'm thinking I can make a set from some old pliers or channel locks, but ordering some for $4 is much more simple.
Thanks
Old Oct 22, 2013 | 10:58 AM
TurboJoe@Straightline's Avatar
tally, where did you get that tool? my current bead roller only has dies for down to 2''. that would be a great tool!!!!
Old Oct 22, 2013 | 11:47 AM
Starts life as a pair of wire crimpers (price went up, was 3.99)
take off the nose in a grinder down to the crimper parts and just clean it up so there's no sharp edges.
forearm gets a workout but its cheap.
Old Oct 22, 2013 | 11:55 AM
HRHohio's Avatar
That's brilliant!!!
Old Oct 22, 2013 | 12:02 PM
cant take credit for coming up with it, 98cobrakiller had it in his build thread a while back
Old Oct 22, 2013 | 12:03 PM
BMF_Racing's Avatar
Question
thats really nice. Did you alter the crimp area at all or is it still the same as it comes (the shape of the crimp area)? Again, great idea!
