8.76@156mph with stock nissan IRS and JY 5.3L...
Its going 7's with a jy l33 with untouched heads and a used cam. Stock Nissan diff too. just suspension, gear, a2w, weight, intake, and a billet 76/92 away. 170+ mph if the l33 will stay together at 28-30psi with that turbo.
Please just let me come out there and gap the rings for you, if you're lazy and don't want to. LOL
I think I may need a built motor either way. But we will find out next spring.
#33
You may not like that tall of a gear. I had real issues getting the car to launch with the glide 1.76 first and a 3:10 gear and 28" tire. Had to launch mine at 24-25lbs to get it to 60' worth a damn. Wish you the best of luck though that setup really works! I'm going with a JY LS1 this winter. Hope it's as tough as the L33!
#34
#35
#36
I've already got 26x10.5 et streets if the 27's don't work. I plan on class racing in the outlaw 8.5 OSCA with the 3.13 gear. So I will have 3 tire options with the 3.13. 26x8.5 slick and 26 or 27x10.5 ET streets for DOT races.
#37
It will only be 8% change with the 26" tires. So
156mph with the current 3.69 and 28"
168mph with 3.13 and 26"
175mph with 3.13 and 27" tires.
I'm thinking the 3.13 gear and 26" tires will be my best setup with the current turbo and JY stock motor. If I give it enough power to pull the 27" tires I may be past what the stock L33 will take????
We will see....
We will see....
#39
So figuring in tc slippage etc. You should be close running your 28's and 7200/7300 rpm...
