Datsun 280z Turbo Build - 5.3 / T7875 / Magnum T56 - Video on page 12!
Old 11-06-2013, 06:12 AM
STEEPSS's Avatar
Default Datsun 280z Turbo Build - 5.3 / T7875 / Magnum T56 - Video on page 12!
If you want to see this from the beginning (lots of time to kill) you can find it here: https://ls1tech.com/forums/conversio...5-3-build.html
Couple of pics to satisfy your curiosity.
Now with boost! (soon!)
Starting a turbo build to get some input on a few items.
Parts list:
Turbonetics T7875 .96AR turbo
Precision 46mm WG
Ebay 50mm BOV
Truck manifolds
2.25 - 2.5" merge
4" downpipe
27x12x3" intercooler (enough?)
new Howe radiator (28.5 x 16")
Holley HP EFI (happening at the same time)
Boost control via holley
120#/ hr Low imp injectors
E85
Magnafuel BR 1:1 FPR
twin external 255 walbro's
-8 feed
-6 return
2005 Iron 5.3L - bought it disassembled, but in good shape.
-Head studs (undecided which)
-Rod bolts (stock, or arp)
-LS9 Gaskets
-LS2 timing chain
-Ball hone and rings?
-Tick Performance custom cam
-LS1 intake / TB
Already in car:
Built T56
Monster 3 Clutch
Ford 8.8 IRS
What suggestions do you guys have about this combo?
Old 11-06-2013, 06:15 AM
STEEPSS's Avatar
Got a little done tonight. Built a radiator and intercooler out of some foam I had laying around. This further reinforced the need to cut out some core support.
Here it is after the bottom half of the core support has been removed.
As you can see, this really opens up the engine bay. I'll likely end up cutting it all out, and making a new one out of sheet metal. This will also go over the radiator in the rear, and become the shroud for the E fan to mount to. That is the current plan anyway.
I also made an intercooler out of foam. Use your imagination.
Old 11-06-2013, 08:37 AM
AmishAssassin's Avatar
Good thing you got the diff sorted out while it was N/A haha this is one of my favorite builds and you always do quality write ups, best of luck!
Old 11-06-2013, 09:31 AM
STEEPSS's Avatar
Thanks man.
Yeah, it went a best of a 1.48 60' this year, with plenty of 1.500 and 1.5x's. The diff loved it! I will be making a little bit more robust mounting system for it though, i was still getting some flex from the current mounts on launch.
Old 11-06-2013, 09:48 AM
be good's Avatar
sweet build.
Old 11-06-2013, 09:49 AM
DEFYANT's Avatar
I loved your original build! Glad to see this one rolling around!
Old 11-12-2013, 05:56 AM
STEEPSS's Avatar
Worked on locating the turbo tonight.
Trying to run this, or the 2520 filter which is 5". Not sure if it will give me the flow I'll need....? Anyone have experience with this?
http://www.summitracing.com/parts/knn-ru-2510/overview/
Old 11-12-2013, 07:13 AM
S13LSx's Avatar
2" crossover if you haven't already made the larger. It will help spool and I'm making 850-900whp with 2" now with a 75/83 BW S475.
Stock rod bolts unless your spinning to the moon.
Old 11-12-2013, 07:22 AM
STEEPSS's Avatar
hmmm Well I've bought 2.25 already. Maybe I'll just keep that around and buy some 2". I'd be curious to know exactly the difference in spool of 2" vs 2.25".
Old 11-12-2013, 08:28 AM
DEFYANT's Avatar
That filter looks quite smashed. I would look into an aFe unit, they make some very large ones.
Old 11-12-2013, 08:52 AM
skinnies's Avatar
Get a better filter!
That thing is going to haul ***, it should be a 155+ mph car without much trouble at all!
Old 11-12-2013, 09:02 AM
STEEPSS's Avatar
After looking at the CFM of those filters, you guys are completey right.
Anyone have any PN's of some 4" inlet filters that might do the job?
Edit: thoughts on this one? http://www.summitracing.com/parts/afe-24-91009
Also, PN of GM rod bolts for this '05 5.3?
Old 11-12-2013, 09:14 AM
skinnies's Avatar
We use these...
http://www.race-mart.com/Spectre_Per...-SPT-9738.html
Can get at the local oreillys.
Old 11-12-2013, 09:59 AM
Forcefed86's Avatar
From what ive read 2" starts to become a restriction around 1000 crank. Lots of 2.125" piping on ebay. Think ill split the difference and run that. good luck, car looks great!
Old 11-12-2013, 10:46 AM
DEFYANT's Avatar
That aFe looks like a nice piece, just run the absolute biggest you can fit.
On the rod bolt thing, ARP or Katech ones are cheap insurance, unless you don't want to pull the engine.
Old 11-12-2013, 12:45 PM
aknovaman's Avatar
Wink
Get an Ebay cold air initake kit for a 2000-2005 Silverado. They are like $69 and have a huge filter; much larger than the one from Summit. I have one on my 2002 suburban and its very good quality. Plus it comes with the intake elbow, and silicone adpters and an aluminum tube.
It saves a couple bux and works well.
Old 11-12-2013, 12:53 PM
STEEPSS's Avatar
Well the 5.3 is on a stand in my garage right now. Haven't heard what the consensus is on re-sizing rods with the ARP's.
Not a bad option.
Old 11-12-2013, 10:14 PM
STEEPSS's Avatar
Bends showed up today, so I was able to get to work on a couple small things. Started with my 3" to 4" transition for my downpipe. Bought this 2.25"-4" cone from columbia river, and had the v band.
High tech, precision scribing device
Cut using cutoff wheel on 4" angle grinder, and cleaned up
Finished Product:
Old 11-13-2013, 01:05 AM
RonSSNova's Avatar
Nice work! I always appreciate a craftsman. (Not the tools)
Ron
Old 11-13-2013, 10:20 PM
STEEPSS's Avatar
More downpipe.
Quick Reply: Datsun 280z Turbo Build - 5.3 / T7875 / Magnum T56 - Video on page 12!
