2001 5.3 turbo impala ss
#41
been really busy with work but I got everything ripped back out. goin to get the engine bay painted and finish up the motor
![](http://img839.imageshack.us/img839/2562/dr32.jpg)
Uploaded with ImageShack.us
also got my radiator for Christmas
![](http://img138.imageshack.us/img138/6351/3uc8.jpg)
![](http://img15.imageshack.us/img15/4092/69vr.jpg)
#42
pulled the nose apart, getting the frame ready to shoot black base/clear
![](http://img716.imageshack.us/img716/5023/iw1m.jpg)
#44
#46
#48
#49
progress is slow due to work still. but here are some updates..
front end is all together new everything.
![](http://i59.tinypic.com/257oh34.jpg)
also got the engine bay painted body color
![](http://i58.tinypic.com/2holjpu.jpg)
![](http://i60.tinypic.com/2lbf29k.jpg)
![](http://i60.tinypic.com/2dpavm.jpg)
waiting on my oil pan to have the 10an bung welded into it so I can drop the motor back in and start the plumbing and wiring
![](http://i58.tinypic.com/2hs1zb7.jpg)
#50
making more progress. motor is bolted into the car, return bung welded to the pan, supply plate above oil filter installed. cam,springs,ls2 timing chain in. and got the hot side amd down pipe coated and wrapped. slowly getting there
![](http://i58.tinypic.com/15clmkl.jpg)
![](http://i62.tinypic.com/2a62kwn.jpg)
![](http://i61.tinypic.com/33vjm8k.jpg)
![](http://i61.tinypic.com/18dle8.jpg)
![](http://i59.tinypic.com/28jjkw6.jpg)
![](http://i58.tinypic.com/nq1od3.jpg)
![](http://i61.tinypic.com/w83u5y.jpg)
#52
been picking away at stuff. motors in for good, throttle hooked up, lower elbow for clearance, valve train is back together, belts on, power steering lines are done, plug,wires,coils are on now(not in the pic) slowly getting there. still have to make a turbo bracket to take some weight off the flanges. harness should be done this weekend. 80 lb. ford injectors are installed..
![](http://i57.tinypic.com/eimmb.jpg)
#56
Car got dynoed in sept. On 8-9 lbs. made 475whp thru a 60e and 9" rear drive it for 3 months and took it back apart. Right now it's almost back together. Did a whole new hot side with a on3 78/75 to replace the 76/65 and a full manual 4L80. Should be hitting the dyno in April with 15 lbs. I'll upload pics later today
