Downpipe Flex?
Old Nov 21, 2013 | 12:11 PM
Shownomercy's Avatar
Man-Crush Warning
Default Downpipe Flex?
From the turbo, my downpipe connects to catback via V band and then a regular exhaust out back.
Should I install a flex joint between the turbo and exhaust? IE somewhere in the downpipe. Turbo is mounted to engine block. Solid motor mounts.
Old Nov 21, 2013 | 12:35 PM
JT86SS's Avatar
solid motor mounts, i would say no. i would personally run one anyway because the exhaust is allways moving unless everything is mounted solid (exhaust mounts) to the body. i've used a flex-pipe in my old setup, but i had the rubber motor mounts and rubber exhaust mounts.
Old Nov 21, 2013 | 03:10 PM
Man-Crush Warning
Ok cause I just worry about the stuff flexing and potentially over stressing the turbo housing.
Old Nov 22, 2013 | 04:16 PM
Compressor Surge's Avatar
I'm certain that the 16 gauge tubing would give out before the cast iron turbine housing.
Old Nov 22, 2013 | 04:30 PM
LT1RAY's Avatar
I installed a small flex piece to the exhaust that connects to the downpipe. I have poly mounts. Here's a link to the unit I used.
http://www.siliconeintakes.com/produ...15b065f742542b
Old Nov 22, 2013 | 05:01 PM
SPRAYED 01's Avatar
Not sure if its the right thing to do but i run moly mounts and flex joints any where.
Been like this for over 10k miles with no issues
Old Nov 22, 2013 | 06:19 PM
Man-Crush Warning
A cast piece is much more susceptible to vibration fatigue than a cold worked pipe IMO.
Old Nov 22, 2013 | 06:47 PM
sbcgenII's Avatar
Are you using the stock rubber pieces on the exhaust hangers?
Old Nov 22, 2013 | 06:54 PM
Man-Crush Warning
Theres nothing stock left.
But yes, rubber mount on the pipe down the trans tunnel.
Old Nov 23, 2013 | 10:41 AM
ACCLR8N's Avatar
Not necessary.The rest of the exhaust has room to move. The heavy cast turbine housing is in no danger. Just be sure the weight is supported. I have flex joints in my cross over and wastegate pipe as they are mounted rigid at each end.
