Post up pre and post intercooler pressures.
Old Nov 21, 2013 | 07:26 PM
SPRAYED 01's Avatar
Default Post up pre and post intercooler pressures.
Its hard to find real world data on this so I figured Id start a thread.
Post up size and brand
Boost level
Piping size
Pre ic pressure and post or intake pressure.
Old Nov 21, 2013 | 07:55 PM
lmt0705's Avatar
my last build with the intercooler kit bob from brute speed was selling was 18psi going into the intercooler and 15.5 at the intake.
Old Nov 21, 2013 | 08:22 PM
SPRAYED 01's Avatar
What size? Was that a Chinese one?
Old Nov 22, 2013 | 04:58 PM
SPRAYED 01's Avatar
So here is mine
20psi intake
25.5 pre IC
CX 31x12x4, the common ebay one with 3 inch charge pipes
Making 835whp at that time
Old Nov 23, 2013 | 07:04 AM
skinnies's Avatar
threadstone 1000hp twin turbo ic
2.5 in both sides, 3" out
Ran mostly at 25.5lbs, less than 1.5psi drop, less than 2 psi at 31lbs when boost spiked once.
8.32 at 171.99mph at 3040lbs
Old Nov 23, 2013 | 08:23 AM
stevieturbo's Avatar
You also need to factor in air temps pre/post
My first DIY cooler had virtually no pressure drop...but it also had crap cooling.
Old Nov 23, 2013 | 08:24 AM
skinnies's Avatar
exactly!
Old Nov 24, 2013 | 09:48 PM
SPRAYED 01's Avatar
Good point, any one else?
