862 heads for turbo 5 3??
Old 11-24-2013 | 01:57 PM
Benji17's Avatar
Default 862 heads for turbo 5 3??
Pretty self explanatory title...
Just bought an lm7 with 862 heads. Should I keep those or get something else? Plan on going turbo and shooting for 650-700 whp.
Old 11-24-2013 | 02:08 PM
Wicked69's Avatar
I ran the 862' and ON3 twin 70's. I went a best of 6.04 in the 1/8th in a 3720lb daily driver. I think those heads work well on the 5.3 with FI.
Old 11-24-2013 | 03:05 PM
10secZ28's Avatar
I agree, I made 844 on 22 lbs with a set of untouched 862s they work just fine
Old 11-24-2013 | 03:47 PM
Benji17's Avatar
Awesome. Thanks guys. Just wanted to make sure since I see all these guys running different heads with port jobs and what not. So I wasn't sure. Haha
Old 11-24-2013 | 08:26 PM
73turbo53's Avatar
They are working great for me also.
Old 11-24-2013 | 08:30 PM
2muchboostNY's Avatar
What rpm are you guys spinning the oem heads to? I was thinking about buying the Trunion Upgrade kit...worth the cash of even needed? Already dropping in a BTR Spring and Retainer kit in there for good measures.
Old 11-24-2013 | 08:37 PM
Benji17's Avatar
^^^ Good question!! I'm not really concerned about rpm's too much. Would I need to upgrade springs and retainers? Should I just go ajead and do it since I have the motor apart?
Old 11-24-2013 | 09:36 PM
Wicked69's Avatar
I up graded to Brian Tooley Springs. I run stock rockers though but I only run to 7k max. No trunion upgrade
Old 11-24-2013 | 10:51 PM
Sorry for the thread jack OP...I presumed you would also ask similar questions. I did the BTR Spring Retainer Kit because I too wanted to spin to around 7k rpm. Depending on what rpms you will be spinning too and what cam you use, some people have gotten nice results with PAC single springs and retainers. I did the BTR kit because of my goal.
