Forged 5.3 options
Could you elaborate on the timing chain failure?
If you are going through the trouble of a forged motor build a 4” bore engine. Parts are cheaper.
My motor build was a joke really. It was for mockup only, but I ended up running it. (link in sig) Had the original 160k crank gear, random cam gear, and I don’t even know where the timing chain came from at this point. It may have used the original 160k chain now that I think back on it. Had a good 3/8”+ slack in it as well. Ran it all season that way and kept the rpms under 6500. Got a little greedy in the burnout box right before the chain let loose and hit 7100-7200rpm and was rapidly feathering the gas pedal. Setup to launch on the 2 step and the motor blew on the line at 3600rpm on the 2 step.
$220 well spent I say!
so can someone fill me in, is it as simple as boring to the 5.7 stock bore, use 5.3 forged rods n stock crank? Or gta run 5.7 rods n crank? Sorry if its a stupid question, i never pay attention to ls1 stroke specs etc.
Used forged ls1 bore size forged pistons or
Find a nib deal that someone wants to sale cheap
An the 350 buck scat I beam rods
I picked up some low mile Ross ls1 bore size pistons looked about like new for 180 bucks on stock rods with arp bolts lol
