injectors for e85 6.0 s480 build
Sounds like you could be making enough power that your pumps are running out of steam to me. Doesn’t really matter how you add more pump. Whatever is easiest for you. I like the idea of less pumps personally. if your current pumps are intank, I’d replace them both with the 450lph e85 walbro pumps.
If your external and running inline pumps, adding another 255 would be easiest. You can use the 3:1 shop air fittings for a nice cheap 255 inline coupler. I just tapped out the 3/8” hole on the bottom to -10 fittings thread pitch and go. The one I did turned out slick.
2 of these. 3 pumps in the middle with cheapie push lock AN6 fittings.
I am going to run it on the current setup and see what my dc is for now. If my injectors keep trying too add fuel and pressure and afr isn't where I want then pump change will be in order.
Do a search, this has been talked to death 100+ times.
If you are maxing out 80#injectos before this you don't have enough pump or you have other issues.
69 base!!!! damn can the ecu control them without mechanical lockup at that psi?
Most of the injectors I've read about are rated to 100psi. Keep it under there and you *should* be good. I'm not makin any promises though!
