DIY TRIPLE PUMPS on the quick and cheap
Thanks to the people in this post for reminding & re-inspiring me.
https://ls1tech.com/forums/fueling-i...lbro-guys.html
3 way air manifold drilled inlet to 11/16 and tapped 1/2" NPT (for -8AN) $6
Some minor work inside to unshroud the ports, it was originally intended as a splitter not a collector.
I know I said I wouldn't but I did the trap door mod on my own ws6. I went to pull the tank and my TRZ anti-roll system is welded in the way!
Here is the set up donated from my formula, twin walbro's untouched in like 6 years got the car to where it is now.
Out with the old..In with the new! 3 brass 1/4npt to 5/16 barbs $6
3 gss340's from New Era Performance $300 shipped.
The fit.. no tighter than the twin pumps.. doh! Fun to get the level float in tho.
The results.... in [SIZE="4"]HD[/SIZE]
.. Takes 30 minutes to drop the tank if your flying solo people.. dont cut the **** out of your cars body because your too lazy to take 30 minutes to drop a heat shield and take out a few bolts.
Seriously.. cuttiing a hole in the body to swap a pump up is as butch as it gets.
If you dont have choice like MM you gotta do what you gotta do... but otherwise its just stupid to do that IMO. You can also make an argument for safety reasons as well if you wanted to but I guess but to each his own.
I know my left from my right and removing a metal tank is a 2hr job on these cars without bars welded in front of it.the 3 way manifold can be found at most tool or home improvement stores. or google 3 way air manifold. reminder that it comes wtih 3/8 npt inlet which i enlarged.
the car will run on one pump as usual out of boost. when i floor it the other two will cut on with tps as current.
the second pump relay will be upgraded from 30 to 40amps and the third pump will get its own wiring over to that relay and a fresh ground. fuse will probably go from 15 to 25A
this is a metal tank car.
avk threaded inserts may be a newb move so please excuse the butchery
the trz issue... slight possibility a plastic tank could make it out.
