DIY TRIPLE PUMPS on the quick and cheap
i can't imagine why it would not work awesome.
should get me to 1200 wheel horse with fuel to spare on e85
Again, what kind of power are you looking for?
What BSFC are you using to calculate flow necessities?
That sounds awesome. Post some pictures of it.
There was no details of how it was tested, or what it was flowing.
"A lot" isnt really sufficient for designing a fuel system, or for making comparisons with other designs.
I have one quick question. How do you make it so you have one pump running full time and one or two kicking on under boost? My plan is a dual setup with one Walbro running all the time and a second coming on under boost. Confused as to how to keep one off while the other is running until you want it to turn on. Thanks man!
1 pump always one. 2 & 3 come on at 2psi + hobbs
Factory fuel level works with modified bucket. just cut 90% of the bucket. Only concern now is the bucket not holding any fluid. The metal tanks ive heard actually have built in baffles in the tank?
