Whats a good turbo cam for my LQ4 turbo street build? Opinions needed
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Before posting I did search alot of threads for some info.
I am doing a build over the winter and I am kinda on the fence about changing out the cams. Looking to get the power and torque in the lower rpm for the street on a 76mm turbo on E85. I was looking at doing a custom cam, 231/239 114 LSA or a Comp 227/235 113 LSA.
Which cam would be great for this or any other different one's out there?
Thanks
Thanks
Contact Martin from Tick performance he will get you what your looking for.
https://www.tickperformance.com/cont...mworksheet.pdf
With choosing those 2 cams you posted, you have to take into account what intake and heads you are running plus the turbo plays a role in cam selection too. Just like many have posted here, get in touch with Martin@Tick, Geoff@EPS, PatG, or John@lil john motorsports and give them the info they need to get you a cam that will perform well throughout the rpm range and spool the turbo you are using.
