Making a turbo list and checking it twice
Old Dec 24, 2013 | 06:14 PM
transaminator99's Avatar
Default Making a turbo list and checking it twice
i know corny lol but im getting ready to do a budget turbo build on my trans am and am just looking for conformation on my list and possible suggestions
t76 on3 turbo
modular turbo hotside
ebay intercooler kit
probably bov and wastegate from modular
oil feed and drain with scavenge pump to oil fill
modular oil feed block
modular ps lines
modular alternator relocation
60lb seimen injectors
aeromotive 340 lph pump
colbalt 2 bar map
317 heads
ls9 head gaskets
arp head bolts
regap rings
ls2 timing chain
chain guide
aeromotive euro wideband
boost gauge
monster stage 3 clutch
tune by frost i live in va
10 psi most likely or 8 looking for 530-560rwhp i have tsp 228r in the car already .... dont plan on track use so im keeping the stock rear until i get funds again ...any help is greatly appreciated this is my first time boosting and just want to cover all my bases i dont plan on brfpr or anything like that i just plan on running stock lines and rails and im doing speed air density ...i also have a ls6 oil pump with .125 washer in relief spring .... thank you guys in advance
Old Dec 24, 2013 | 07:04 PM
allout06's Avatar
I would go with a walbro pump and a 12615136 2 bar map. Also, do ARP head STUDS not bolts. Other than that I think the list looks pretty good. Im assuming you have dual valve springs and a set of pushrods when u did the cam
a double roller timing set is also a nice piece of mind. The ls2 will work but better safe than sorry..
Old Dec 24, 2013 | 07:20 PM
Black89Z51's Avatar
Ive heard Frost is pretty good. Depending on where in VA you are, I'd also consider Ed Hutchings.
Old Dec 24, 2013 | 09:01 PM
BigBadWhitey's Avatar
Are the studs really a necessity at 8-10psi? Just out of curiosity as they are about double the price.
Old Dec 24, 2013 | 09:05 PM
HexenLord's Avatar
If you ever plan to remove the heads for whatever reason, the studs instantly pay for themselves.
There are other affordable options out there for head studs other than ARP. You seem to have pretty modest goals so you don't need to strive for the strongest and most expensive studs.
Btw, if you're really worried about throwing out the extra $90, then a turbo build is not for you.
Old Dec 24, 2013 | 09:13 PM
831jd's Avatar
Gt45 would be better
Old Dec 24, 2013 | 09:23 PM
HexenLord's Avatar
In what way other than price? If he gets the .96 a/r, the on3 should make more power. Its also MUCH smaller physically than the GT45 which will fix a lot of fitment issues.
Old Dec 24, 2013 | 10:08 PM
831jd's Avatar
The little 64 wheel will choke up if he wants to turn up the boost before the gt45 will I just made over 700 with the gt45 on low boost 15-16psi
Old Dec 24, 2013 | 10:22 PM
HexenLord's Avatar
I've seen someone on this board make 677 whp through an unlocked 4L80e at 15 PSI with the on3. That puts it right on par with your numbers.
Old Dec 25, 2013 | 12:03 AM
itsslow98's Avatar
I would also say head studs and I would also recommend a better turbo. Even a turbonetics tc76 would be more reliable. You gotta remember that if that turbo blows during a WOT run your motors probably going with it.
Old Dec 25, 2013 | 01:06 AM
HRHohio's Avatar
Just curious...
What are you basing this on with regards to the TC76 being more reliable than the On3 76mm? The implication you've made is that there is a greater likelihood of the On3 turbo blowing up. I haven't heard of any trends that the On3's blow up and take out motors at WOT. Where's that coming from?
Again... just curious.
Old Dec 25, 2013 | 01:50 AM
itsslow98's Avatar
Originally Posted by HRHohio
Just curious...
Do some searches here and on other forums......and ive seen some blown up chinese turbos in person. Its a small price to pay for peace of mind but it is up to the user in the end.
Old Dec 25, 2013 | 02:15 AM
HRHohio's Avatar
Interesting. I can't say I've come across any threads about a catastrophic turbo failure for On3 Turbos. Not saying that there is no such animal. Just that I don't think there's any statistical evidence that it happens more frequently than any other brand. That's all. Sounds like a wive's tale to me.
Did the blown up chinese turbo of which you speak take out the whole engine too?
Generally, my understanding is that when most turbo's fail, the owner notices that it doesn't make any boost, inspects, and finds considerable shaft play and the bearings would leak oil. I don't know of any street/strip cars that have had an On3 turbo go to catastrophic failure at WOT like you mentioned. If you know of any (or anyone else does), I'd be interested to hear about it, especially since I've got one on my car. No issues in 15k miles.
Old Dec 25, 2013 | 03:15 AM
Arent the ARP headbolts reuseable, they aren't TTY? Also im in for some info on other studs, all I can seem to find is procomps. Its not so much about a worry about 90$ difference, its more so whats necessary for said goals. If you said "Whats 50% increased cost" on every single part you buy, you go from a 15k build to a 30k build.
Old Dec 25, 2013 | 03:24 AM
831jd's Avatar
I was on a 4l80 also gt45 cheaper but bigger that the bad side
Old Dec 25, 2013 | 03:32 AM
itsslow98's Avatar
Ill ask my buddy who owns the shop and see if i can find the details. Ive heard an equal amount of success stories with them in budget builds so i shouldnt really rule them out but its just my preference.
Old Dec 25, 2013 | 03:42 AM
stoning_volcom's Avatar
That list looks complete, I would when you get the 317's clean up the exhaust ports and try to smooth them with some tootsie rolls. Just make sure you build around thepossiblity of wanting more power. That tends to happen
I would disagree, most companies have there products made in china and they make there way onto plenty of high horsepower cars. They are all made the same way. I would suggest taking apart the cheap turbos and inspect and measure everything to make sure it does not prematurly fail. As for the ON3 turbo, dont listen to the negative people, they are just mad they spent 1500$ instead of 500 and are making the same power. As for the turbo taking out the enigne, if that is the case then the people that run into that are fing stupid. You would be able to hear it.
Old Dec 25, 2013 | 06:35 AM
marutizhiyi's Avatar
Old Dec 25, 2013 | 09:35 AM
HexenLord's Avatar
Back when I was working for Source Interlink, I seen about a hundred Garrett, Precision, and Turbonetics failures.
I've seen all of 3 chinese turbo failures. 2 of them were back when the Chinese were first producing knockoffs, and the third was from oil starvation.
Not saying the cheaper turbos are more reliable. The name brand turbos obviously are capable of more power, especially with options like billet wheels and upgraded compressor housings. The problem is that so many people give them a bad reputation because they 'heard' they were bad.
Old Dec 25, 2013 | 12:33 PM
HRHohio's Avatar
Ill ask my buddy who owns the shop and see if i can find the details. Ive heard an equal amount of success stories with them in budget builds so i shouldn't really rule them out but its just my preference.
I hear ya. I think the china turbos have about the same rate of failure as any other turbo. Just because it comes from a foreign country doesn't mean it's junk and will take out an engine. Nowadays, with the global market, turbos are being made all over the world, China, Brazil, Mexico, even India. Even Garrett has manufacturing plants in China...
http://garrettbyhoneywell.com/about-...wide-presence/
Most of the stories about "Chinese Turbos" failing start out as spun journal bearings due to improper oiling... then someone latches onto that story and tells it to a friend and it changes from a failed bearing to "That turbo blew up"... that in turn perpetuates to the lore of "taking out engines". Again... not saying that they can't fail in that manner, but probably the same failure rate as a Garrett, Turbonetics, or Borg Warner (Catasrophic failure I'm talking about). And like mentioned before, if you see a cloud of smoke behind your turbo car... shut the engine down and check it out. "Chinese Turbos taking out engines" is more lore than not.
Sorry OP if this got off topic. I just don't like unfounded stories being perpetuated. You should be fine with an On3 Turbo in your build, especially at sub 1000rwhp levels.
Good luck!
