347+Boost=Good Idea?
Old Jan 2, 2014 | 09:07 PM
yonerhottlt1's Avatar
Originally Posted by allout06
Friend of mine is using a stock LS2 block. 403 stroker. 11.8:1 CR, F1C, 940rwhp @ 15psi.
Sheesh...must be running E85 or some kinda race fuel?!
Old Jan 2, 2014 | 09:20 PM
FlashWS6's Avatar
Destroyer of Exotics
347 will be ok for now, once we turn it up tho...
Old Jan 3, 2014 | 06:48 AM
LS6427's Avatar
Seriously.....15psi with 11.8:1 cr.....?
Everyone was telling me I'm crazy for wanting to go 18psi on 10.2:1 cr with my iron forged 390ci........
What's he using for fuel?
Old Jan 3, 2014 | 06:53 AM
ls1curt's Avatar
I'm running 10.5:1 in mine, 17 psi on pump + meth
Old Jan 3, 2014 | 07:00 AM
LS6427's Avatar
Richard at WCCH has LSA heads of his that will get me to about 10:1 cr.
You think I'll be fine at 18-20psi with the Modular Turbo....Twin Turbo kit?
Full time E85 is the plan.......
Old Jan 3, 2014 | 07:04 AM
ls1curt's Avatar
No problem....
Old Jan 3, 2014 | 07:13 AM
LS6427's Avatar
No problem....
Without meth ok.....?
Just the A2W + E85....?
Or should I use meth?
.....the Modular Turbo kit comes with an A2W IC.....?
I was thinking of using a KILLER CHILLER too.......they seem like they work great on the Mecedes SC'ed and turbo cars.
Old Jan 3, 2014 | 08:45 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
I'm north of 10.2:1 and north of 17psi and I don't have any issues with knock. Granted, I'm spraying meth/water, but still, no reason you need to go into the 9's for compression if you aren't pushing really high boost.
Old Jan 3, 2014 | 08:46 AM
MIGHTYMOUSE's Avatar
i cracked a 5.7 sleeve around the 900rw mark tho was 10yrs ago
if you oversize the turbo to better manage back pressure, and control the torque spike on the way up you should be able to pass that these days.
Old Jan 3, 2014 | 08:50 AM
Camaro9969's Avatar
A2W E85 if you have it available near you if not might as well use meth.
Old Jan 3, 2014 | 08:58 AM
LS6427's Avatar
Yup.....E85 all over around me.
What do you think about the Killer Chiller....?
Old Jan 3, 2014 | 09:26 AM
  #32
Twin turbo c5's Avatar
I made 670 to the wheels. I daily drive mine and i'm always on the boost I built the car 2 years ago and no issue since on a bone stock 5.7. Nothing wrong with the aluminum block at all.
Old Jan 3, 2014 | 11:46 AM
  #33
01 WS6 6.0's Avatar
Car will be on pump and meth (M1) A2A for the time being then upgrading to a A2W later on to better maintain lower IAT's. Motor will be right around 10.2:1 compression with a 317 head for now. Car will be on kill rarely 800rwhp in a 2900 pound car should get it out of it's own way. Again thanks for replies guys I appreciate it very much!
Old Jan 3, 2014 | 01:58 PM
  #34
fotoboy's Avatar
Originally Posted by Heavy H.P.
Damn that bad boy is making some tq!
My guess is that's verter flash for that kinda tq.
5.7 98 ls1 block forged and so far 817 whp and 772 wtq.
Old Jan 3, 2014 | 02:02 PM
  #35
smokeshow's Avatar
I'd bet money its a mustang dyno.
Old Jan 3, 2014 | 02:09 PM
  #36
Heavy H.P.'s Avatar
I kept looking at those numbers like damn. Almost a 1000rwtq, damn.
Old Jan 3, 2014 | 02:20 PM
  #37
fotoboy's Avatar
I've seen this exact thing happen on a mustang Dyno. No tach lead and just speed based will do this. I've also seen similar but no that exaggerated on a Dyno jet. Auto cars need to be started near there flash point IMO either way.
