Huron Speed NEW Products - Power Steering, Oil Feed/Drain, and Fuel LINE KITS!
Old 01-12-2014 | 08:22 AM
Superman09's Avatar
LS1Tech Sponsor
Default Huron Speed NEW Products - Power Steering, Oil Feed/Drain, and Fuel LINE KITS!
We have a few new products to offer everyone for their turbo build needs along with just generally wanting to clean up the engine bay with these new products!
Power Steering Line Kit.
http://shop.huronspeedproducts.com/9...it-pslines.htm
-Allows you to easily route the Power Steering lines where you wish to clear turbo piping as we all know the factory lines are directly in the way on most set-ups and require bending and working around.
-Kit includes a new Braided Pressure and Return Line.
-New fitting for the pump and 2 new fittings for the rack to directly bolt the new lines up.
-A clamp to secure the rubber connection to the reservoir.
-A clamp and bolt to secure the pressure line to the block if you wish to run it in that orientation.
Oil Feed and Drain Line Kit
http://shop.huronspeedproducts.com/9...s-oillines.htm
-Standard kit lengths were made around our T4 kits with a Stainless Braided -4an Feed Line at 42" long with (1) 90* end and (1) straight end.
-Standard kit lengths again built around our T4 kits offer a Stainless Braided -10an Drain line in a 26" or 35" length with 90* fittings at each end.
-Kits come with (2) -4an to 1/8"NPT fittings and (2) -10an to 1/2"NPT fittings to connect your lines.
*Custom lengths available. Simple choose that option and let us know which lengths you need!
Engine Bay Fuel Line Kit
http://shop.huronspeedproducts.com/L...ellinesls1.htm
The kit includes both the fuel and evap lines and GM quick connect adapters. This is a 'plug and play' setup, no modifications are required to the stock fuel/evap system. Stainless Braided Lines with Black Fittings!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 01-12-2014 | 09:35 AM
kylemm1002's Avatar
I was just looking into the power steering line stuff yesterday. Looks like a good option.
Old 01-12-2014 | 11:24 AM
crazyelf's Avatar
Very nice guys!
Old 01-13-2014 | 10:16 PM
Superman09's Avatar
LS1Tech Sponsor
Thanks for the orders, all shipped out today!
__________________
Old 01-14-2014 | 09:25 PM
gi8e7oi825's Avatar
what are the technical specs on the power steering hose?
Old 01-14-2014 | 10:25 PM
SMOKNSS's Avatar
Nice looking stuff. Good job, guys.
Old 01-15-2014 | 05:07 PM
Majestic9C1's Avatar
the braided fuel line is fine for mildly stock vehicles to get rid of that ugly stock hoses with tin foil wrapped around it.
may have to look into getting a set.
Old 01-15-2014 | 05:53 PM
Superman09's Avatar
LS1Tech Sponsor
I think the most important thing would be construction (this hose has two inner braid reinforcements which you won't see in standard braided hose for gas and oil systems), max operating pressure, and the fact that the hose is made specifically for power steering systems (so it will sustain higher pressure spikes) is quite important.
The hose ends are steel (zinc finished I believe)- can't use aluminum in a power steering system because of the high pressure. They'd blow out.
Notes
Construction: AQP elastomer inner tube, polyester inner braid, single wire-braid reinforcement, and black polyester braid cover.
Temperature Range: Suitable for many applications between -55°F to +300°F, except air +250°F.
Applications: Power steering lines, hydraulics, air, gasoline, fuel and lubricating oils, over-the-wall air tools, and DOT-approved air brake.
Specs
Hose Id 0.31"
Hose Od 0.67"
Max Operating Pressure 2,250 Psi
Min Bend Radius 4"
Jon
__________________
Old 01-15-2014 | 07:40 PM
kylemm1002's Avatar
Just received mine today. Looks like good quality. Going to install it this weekend!
Old 01-15-2014 | 08:05 PM
mightybird's Avatar
Thanks Jon! My oil lines look great ! I may look into the power steering lines as my build progresses !
Old 01-17-2014 | 08:56 AM
Superman09's Avatar
LS1Tech Sponsor
Thanks guys! Appreciate it
__________________
Old 01-20-2014 | 05:39 AM
Superman09's Avatar
LS1Tech Sponsor
Thanks for the weekend orders, all will be shipped TODAY!
__________________
Old 01-25-2014 | 07:47 PM
Superman09's Avatar
LS1Tech Sponsor
All orders have SHIPPED!
__________________
Old 01-26-2014 | 03:26 AM
vettewreck's Avatar
what if I need longer oil drain/feed lines bc my turbos have to be mounted behind the bumper on a swap car? Can you guys make longer lines if I request?
Old 01-26-2014 | 08:42 AM
Superman09's Avatar
LS1Tech Sponsor
Yes, no problem at all! All info for custom length lines is listed on the site here: http://shop.huronspeedproducts.com/9...s-oillines.htm
__________________
Quick Reply: Huron Speed NEW Products - Power Steering, Oil Feed/Drain, and Fuel LINE KITS!
